#2383 - 06/27/02 05:22 PM Re: IC6.5A Locations
Dear Linda
Quik Reports V6.5A did not become compatible with IC6.5 until the 980729 release. If you are using an earlier version (980212 or earlier), then you should upgrade QR for full compatibilty and expected performance.
Once you are compatible, if you have further problems, please do not hesitate to contact us. There are no known issues reporting on Quantity by Location from IC6.5A using the current version of QR.
Further to this, after installing the QR upgrade, you will have to 'convert' your IC reports to use the newer IC6.5 tables, as well as bringing them up to the new QR release. This is explained in Chapter 11 in the QR manual.
#2384 - 07/04/02 11:54 AM Re: IC6.5A Locations
For the benefit of others reading this, the solution of this question turned out to be report links. The report in question was based on Order Entry details, and was linked to the IC Quantity by Location file. Using the old 6.x IC table, you only had to link these files by the Item Number field. With the new structure of IC 6.5A (and of course the table with it), the linking field needs to be Item number/Location code.
Because Item/Location is not the default choice, the values on the report were in many cases incorrect.
