#22919 - 06/24/10 10:09 AM
Bank Rec GL Interface
Loc: Victoria, BC, Canada
We have set up the Ledger Options in the Bank Rec interface with the following:
Send to GL Reference: Bank Reference Send to GL Description 1: Name Send to GL Description 2: Doc. Description
When we post a "deposit-only" batch in Bank Rec, the information that goes to the GL Account for the bank is as follows: Description 1: Name Description 2: Batch Name The information that goes to the GL account for the offsetting account is as follows: Description 1: Name Description 2: Doc. Description
Is there a way that we can change this so that the Doc. Description also goes to Description 2 for the bank side of the entry, rather than the batch name/description (which in most cases doesn't mean anything or is very general)?
I don't believe this problem exists when we post a regular batch (i.e. not a "deposit-only" batch).
Thank you, Tanja
#22921 - 06/24/10 10:44 AM
Re: Bank Rec GL Interface
[Re: Softrak Support]
Thanks very much. I will make this change and see how it works for us. Is there a standard setup that most people use as far as what fields from BR go to what fields in GL?
#22962 - 06/28/10 08:24 AM
I have made this change and have created and posted a deposit-only batch in BR however it is still sending the Batch Name from BR to the Bank account description line in GL rather than the header description from the entry. Any other suggestions?
Thanks, Tanja
#22973 - 06/28/10 10:43 AM
[Re: Cool Aid]
What are you referring to by this? In BankRec there is only one possible combination, not two as you appear to be indicating.
#22978 - 06/28/10 12:30 PM
Thank you for clarifying and for requesting a change to the program. We will work around in the meantime.
14567 Topics
