#22632 - 06/09/10 06:33 AM Changing vendor in active PO
Acrylon Offline
We have a PO that has that has the incorrect Vendor Number on it. Is it possible to change the Vendor Number? We are trying to avoid the usual "delete and create a new one" solution because it is a fairly lengthy PO.
Purchase Orders version 8.1A 091029
#22633 - 06/09/10 07:02 AM Re: Changing vendor in active PO [Re: Acrylon]
Sure you can. Just make sure to do it in both the header and the detail screen.
#22634 - 06/09/10 07:33 AM Re: Changing vendor in active PO [Re: Steve Schwartz]
Acrylon Offline
I have changed it in the Header and in the Details tabs but when I post it, the following message pops up: "The primary vendor is not being used on this document. The primary vendor will be set to A106 (which is the incorrect vendor we are trying to change from)."
#22635 - 06/09/10 08:24 AM Re: Changing vendor in active PO [Re: Steve Schwartz]
Acrylon Offline
We have figured it out. Turned out we had to go through every line and change the vendor in the comment as well. Thanks!
1 registered (Samuel Kopstick), 200 Guests and 0 Spiders online.
14643 Topics
