#21691 - 04/08/10 09:06 AM
Double Sided Printing
Loc: BC Canada
In the GL, How do I consistently get reports to print out double-sided? The default setting in my computer is double-sided, but Adagio seems to have trouble recognizing it and, more often than not, prints out single-sided, even after I have double-checked the set-up options within Adagio. This is problematic for the larger reports, like the general ledger.
Thanks!
#21695 - 04/08/10 09:29 AM
Re: Double Sided Printing
[Re: Anna R.]
Hi Anna,
I'm pretty sure that Adagio doesn't change the printer settings for "sidedness", so my guess is that something (or someone) else is changing them on you.
If you create a logical printer with the double-sided option set, you can tell Adagio to print all its reports to this printer (under File | Options).
#21704 - 04/08/10 01:19 PM
[Re: Retired_Guy]
Loc: BC Canada
Thank you for the advice. I already have a logical printer set-up and that doesn't seem to have resolved the problem. However, upon experimenting, I have just discovered that if I go into the preview pane, click on set-up and verify the print setting, then press print from the preview pane, it will double-side. If I omit this extra step it single-sides, regardless of the settings defined in the print options, and regardless of whether I print from this pane or simply choose print.
#21802 - 04/14/10 09:13 AM
[Re: Softrak Support]
Loc: BC Canada
Sorry for taking so long to reply. I am using version 9.0B (090703) I have no trouble printing double-sided from the AR module, only the GL.
Regards Anna
0 registered (),
261
Guests and
Spider online. |
14617 Topics
