#21691 - 04/08/10 10:06 AM Double Sided Printing
Anna R. Offline
Loc: BC Canada
In the GL, How do I consistently get reports to print out double-sided? The default setting in my computer is double-sided, but Adagio seems to have trouble recognizing it and, more often than not, prints out single-sided, even after I have double-checked the set-up options within Adagio. This is problematic for the larger reports, like the general ledger.
Thanks!
#21695 - 04/08/10 10:29 AM Re: Double Sided Printing [Re: Anna R.]
Hi Anna,
I'm pretty sure that Adagio doesn't change the printer settings for "sidedness", so my guess is that something (or someone) else is changing them on you.
If you create a logical printer with the double-sided option set, you can tell Adagio to print all its reports to this printer (under File | Options).
#21701 - 04/08/10 01:03 PM Re: Double Sided Printing [Re: Retired_Guy]
Anna:
Andrew has the correct answer. You need a rinter driver setup dedicated to duplex printing and then use the File Option as assign this specific printer for your reports.
#21704 - 04/08/10 02:19 PM Re: Double Sided Printing [Re: Retired_Guy]
Anna R. Offline
Loc: BC Canada
Thank you for the advice.
I already have a logical printer set-up and that doesn't seem to have resolved the problem. However, upon experimenting, I have just discovered that if I go into the preview pane, click on set-up and verify the print setting, then press print from the preview pane, it will double-side. If I omit this extra step it single-sides, regardless of the settings defined in the print options, and regardless of whether I print from this pane or simply choose print.
#21705 - 04/08/10 02:57 PM Re: Double Sided Printing [Re: Anna R.]
Hi, Anna,
I'm curious. Exactly what version and release date of Ledger are you using. You can get this information easily by selecting Help | About from the main menu. The release date is the 6 character number in parentheses to the right of the version code.
Also, do you know if reports from other Adagio modules will consistently print double-sided when using the Print button?
#21711 - 04/08/10 04:40 PM Re: Double Sided Printing [Re: Softrak Support]
It's definitely not necessary to go through these extra steps (though this may have been a issue with older versions of Adagio).
#21714 - 04/08/10 04:48 PM Re: Double Sided Printing [Re: Douglas Dickie]
Hi Anna,
What version of Adagio Ledger are you using? The can be checked from the Help menu and About.
We have had a few clients indicate that the duplexing when printing reports did not work in Adagio Ledger where it did in every other Adagio program. In many cases using a different printer or driver worked, and in some cases the problem was isolated to some reports in Ledger and not others.
#21802 - 04/14/10 10:13 AM Re: Double Sided Printing [Re: Softrak Support]
Anna R. Offline
Loc: BC Canada
Sorry for taking so long to reply. I am using version 9.0B (090703)
I have no trouble printing double-sided from the AR module, only the GL.
Regards
Anna
#21803 - 04/14/10 10:23 AM Re: Double Sided Printing [Re: Anna R.]
Hi, Anna,
There is a GL9.0B hotfix that may resolve this problem for you. It does resolve some other issues that were reported but I dont' have verification about this problem in particular.
If you contact your dealer, they will be able to get this hotfix for you. After it's installed, I would appreciate you posting to let us know if the problem was resolved for you or not.
