#21615 - 04/03/10 10:05 AM IC - Active at Location?
Is there a way to view all items in IC and determine whether they are all set to active at our main location?
Also, is there a way to make hundreds of new items that were imported into IC "active" at our main location and "on demand" at our branches? Or do we have to go through in IC/Edit Item/Location tab one by one?
#21617 - 04/06/10 05:30 AM Re: IC - Active at Location? [Re: SusanTennier]
Ryan Brohman Offline
Susan,
In IC from the Edit menu, select Locations. The "Items" tab allows you to see the entire list of items and whether they're active at this location or not.
The "Item Range" tab allows you to select multiple items to make them active at the chosen location. What we typically do is assign a unique Report Group when we import the new items. You can then select the item range based on Report Group for each location. Once this is done, you can re-import the items, overwriting the unique Report group with the desired one.
Ryan Brohman
Kitchener, ON
#21618 - 04/06/10 07:27 AM Re: IC - Active at Location? [Re: Ryan Brohman]
Wow.. this is GREAT. Thank-you Ryan. I will do this tonight when everyone is off the system.
0 registered (), 235 Guests and 2 Spiders online.
14666 Topics
