#20664 - 01/25/10 02:10 PM Drive Cleaning... what can stay and what can go?
Jamie_Reid Offline
New Guy
Loc: BC, Canada
(24.66.233.93)
I am doing a bit of cleaning up before upgrading out of the dark ages of windows 2000 into the new age of xp pro.
My shared drive for adagio has the following and I'm wondering if you can tell me what can stay and what can go please. The drive used to be used for accpac years ago and so anything from that can and will be "archived."
PS - If I'm asking too much, just answer the following... what folders should be on an adagio shared network drive?
L:\>dir
Volume in drive L is ???
Volume Serial Number is 35B5-08DB
Directory of L:\
18/12/2009 02:45 PM <DIR> .
13/02/2006 06:36 AM <DIR> ..
14/03/2006 05:06 PM <DIR> Adagio (has only 2 shortcuts to gridview that we already have in it so I think I can delete it??)
14/03/2006 05:06 PM <DIR> APASP (not changed since 2003)
09/07/2008 05:31 PM <DIR> ASP (current, keep)
14/03/2006 05:10 PM <DIR> bak (not changed since 2003 - assuming old backup directory for something?)
14/03/2006 05:10 PM <DIR> GLASP (2003 again)
14/03/2006 05:10 PM <DIR> HELP (2002)
14/03/2006 05:10 PM <DIR> MEASP (2003)
18/12/2009 02:45 PM <DIR> qrasp (current, keep)
21/04/2009 01:55 PM <DIR> SOFTRAK (current, keep)
14/03/2006 05:20 PM <DIR> TBASP (2002)
10/06/2003 12:18 PM 116 Accpac.bat
05/05/2003 02:53 PM 1,024 GL00560I.CMH
05/05/2003 02:31 PM 8,704 GLBCTLI1.CMH
05/05/2003 02:31 PM 9,728 GLBCTLI2.CMH
21/12/1998 12:00 AM 37,981 PLUS.EXE
27/01/2004 03:17 PM 267 Shortcut to Accpac.lnk
17/09/2002 01:06 PM 22,838 QRTALZ68.TXT
22/10/2003 04:25 PM 4,861 QRTALZ80.QRW
23/10/2006 04:25 PM 89,390 GVREADME.HLP
19/11/2004 03:05 PM 20,494 QRTARW10.QRW
24/11/2006 11:58 AM 21,158 QRTARW10.001
28/04/2006 01:36 PM 34,489 QRTALZ80.TXT
12/08/2003 09:28 AM 6,272 QRTMCW80.TXT
22/06/2007 03:40 PM 180,852 ALreadme.chm
17/03/2006 06:05 PM 22,714 QRTAPW68.QRW
01/01/2001 01:00 PM 192 tempSSI.txt
01/01/2001 01:00 PM 192 tempSSI.001
01/01/2001 01:00 PM 192 tempSSI.002
01/01/2001 01:00 PM 192 tempSSI.003
18/03/2009 02:59 PM 198,352 ReceivablesReadme.chm
01/01/2001 01:00 PM 192 tempSSI.004
01/01/2001 01:00 PM 192 tempSSI.005
01/01/2001 01:00 PM 192 tempSSI.006
01/01/2001 01:00 PM 192 tempSSI.007
18/03/2009 02:59 PM 198,352 ReceivablesReadme.001
13/11/2003 04:11 PM 29,234 QRTARB68.TXT
30/11/2006 04:36 PM 89,614 QRTARZ80.TXT
12/08/2003 09:28 AM 6,272 QRTMCW80.001
14/12/2006 03:39 PM 158,261 CRREADME.HLP
24/11/2006 11:49 AM 128,529 QRTARW10.TXT
13/04/2007 11:14 AM 129,149 QRTARW10.002
20/06/2007 04:41 PM 33,652 QRTARB68.001
30/11/2006 04:36 PM 89,614 QRTARZ80.001
12/08/2003 10:28 AM 6,272 QRTMCW80.002
28/03/2007 03:46 PM 5,925 QRTARZ81.TXT
11/09/2007 03:52 PM 160,879 CRreadme.chm
36 File(s) 1,696,529 bytes
13 Dir(s) 41,548,775,424 bytes free
#20666 - 01/25/10 02:56 PM Re: Drive Cleaning... what can stay and what can go? [Re: Jamie_Reid]
Brian Stief Offline
Waterloo Guy
(208.124.222.4)
Looking at your drive listing, the following folders should be left on your Adagio shared network drive, on the root of the logical drive L:
L:\Softrak
L:\QRASP
L:\ASP
It appears that your data and security files are still pointing to the \ASP folder so leave the entire ASP folder on the root of L:
You didn't say but I'm assuming that no one is using Plus for anything at this point in time.
Since you have converted from Plus, you can gas the GLASP, HELP, APASP, MEASP, TBASP folders, and all the leftover trash files accumulating in the root.
There is no reason to keep the plus.exe unless you are using some add-in that is imbedded in the AP or GL folder, but I cannot think of any that would be added. You can confirm that there are no add-ins by viewing the APver.ld4 and GLver.ld4 with notepad.
If you would prefer, cut these files and folders out (that I suggested gassing) and drop into a temporary folder with a date(off the root) for say 6 months and then completely remove.
Brian
Brian Stief,CPA,CA
800.540.3164
#20667 - 01/25/10 02:58 PM Re: Drive Cleaning... what can stay and what can go? [Re: Jamie_Reid]
You need to keep the following directories;
qrasp
Softrak
You have no directory called 'data' so you would need to determine where that is and keep it as well.
You should not have QR* files in the root, they (likely) belong in the qrasp directory but I would not just replace any existing files. Likley if Adagio is working fine then these are junk.
#20668 - 01/25/10 03:09 PM Re: Drive Cleaning... what can stay and what can go? [Re: Douglas Dickie]
None of the files with numeric extensions (001, etc) are useful.
There are 3 GL data files with CMH extensions dated in 2003. There are no longer useful either.
The .HLP and .CHM help files should be installed elsewhere and not on the root. These are not required here either, and in general are quite old anyway.
As Doug mentioned, the QR files (with QRW extensions) should belong in the QRASP directory. I presume that since these are generally quite old, I bet they are not useful either. Those with TXT extensions are definitely useless and they can be gassed.
#20717 - 01/28/10 06:29 AM Re: Drive Cleaning... what can stay and what can go? [Re: Softrak Support]
Jamie_Reid Offline
New Guy
Loc: BC, Canada
(24.66.233.93)
Thank you - this worked like a charm - just kept ASP, qrasp and Softrak... and archived the rest just in case.
No, there is no need for plus.
Regarding Data - it appears to be in L:\asp\data.
The finance dep't definitely feels virtually cleaner now. I don't think this drive had been cleaned since at least 03ish.
Sorry for taking so long to get back to confirm but circumstances didn't allow.
Jamie
0 registered (), 57 Guests and 2 Spiders online.
1874 Members
14557 Topics
