#20664 - 01/25/10 02:10 PM
Drive Cleaning... what can stay and what can go?
New Guy
Loc: BC, Canada
I am doing a bit of cleaning up before upgrading out of the dark ages of windows 2000 into the new age of xp pro.
My shared drive for adagio has the following and I'm wondering if you can tell me what can stay and what can go please. The drive used to be used for accpac years ago and so anything from that can and will be "archived."
PS - If I'm asking too much, just answer the following... what folders should be on an adagio shared network drive?
L:\>dir Volume in drive L is ??? Volume Serial Number is 35B5-08DB
Directory of L:\
18/12/2009 02:45 PM <DIR> . 13/02/2006 06:36 AM <DIR> .. 14/03/2006 05:06 PM <DIR> Adagio (has only 2 shortcuts to gridview that we already have in it so I think I can delete it??) 14/03/2006 05:06 PM <DIR> APASP (not changed since 2003) 09/07/2008 05:31 PM <DIR> ASP (current, keep) 14/03/2006 05:10 PM <DIR> bak (not changed since 2003 - assuming old backup directory for something?) 14/03/2006 05:10 PM <DIR> GLASP (2003 again) 14/03/2006 05:10 PM <DIR> HELP (2002) 14/03/2006 05:10 PM <DIR> MEASP (2003) 18/12/2009 02:45 PM <DIR> qrasp (current, keep) 21/04/2009 01:55 PM <DIR> SOFTRAK (current, keep) 14/03/2006 05:20 PM <DIR> TBASP (2002) 10/06/2003 12:18 PM 116 Accpac.bat 05/05/2003 02:53 PM 1,024 GL00560I.CMH 05/05/2003 02:31 PM 8,704 GLBCTLI1.CMH 05/05/2003 02:31 PM 9,728 GLBCTLI2.CMH 21/12/1998 12:00 AM 37,981 PLUS.EXE 27/01/2004 03:17 PM 267 Shortcut to Accpac.lnk 17/09/2002 01:06 PM 22,838 QRTALZ68.TXT 22/10/2003 04:25 PM 4,861 QRTALZ80.QRW 18/12/2009 02:45 PM <DIR> 23/10/2006 04:25 PM 89,390 GVREADME.HLP 19/11/2004 03:05 PM 20,494 QRTARW10.QRW 24/11/2006 11:58 AM 21,158 QRTARW10.001 28/04/2006 01:36 PM 34,489 QRTALZ80.TXT 12/08/2003 09:28 AM 6,272 QRTMCW80.TXT 22/06/2007 03:40 PM 180,852 ALreadme.chm 17/03/2006 06:05 PM 22,714 QRTAPW68.QRW 01/01/2001 01:00 PM 192 tempSSI.txt 01/01/2001 01:00 PM 192 tempSSI.001 01/01/2001 01:00 PM 192 tempSSI.002 01/01/2001 01:00 PM 192 tempSSI.003 18/03/2009 02:59 PM 198,352 ReceivablesReadme.chm 01/01/2001 01:00 PM 192 tempSSI.004 01/01/2001 01:00 PM 192 tempSSI.005 01/01/2001 01:00 PM 192 tempSSI.006 01/01/2001 01:00 PM 192 tempSSI.007 18/03/2009 02:59 PM 198,352 ReceivablesReadme.001 13/11/2003 04:11 PM 29,234 QRTARB68.TXT 30/11/2006 04:36 PM 89,614 QRTARZ80.TXT 12/08/2003 09:28 AM 6,272 QRTMCW80.001 14/12/2006 03:39 PM 158,261 CRREADME.HLP 24/11/2006 11:49 AM 128,529 QRTARW10.TXT 13/04/2007 11:14 AM 129,149 QRTARW10.002 20/06/2007 04:41 PM 33,652 QRTARB68.001 30/11/2006 04:36 PM 89,614 QRTARZ80.001 12/08/2003 10:28 AM 6,272 QRTMCW80.002 28/03/2007 03:46 PM 5,925 QRTARZ81.TXT 11/09/2007 03:52 PM 160,879 CRreadme.chm 36 File(s) 1,696,529 bytes 13 Dir(s) 41,548,775,424 bytes free
#20666 - 01/25/10 02:56 PM
Re: Drive Cleaning... what can stay and what can go?
[Re: Jamie_Reid]
Waterloo Guy
Hi, Looking at your drive listing, the following folders should be left on your Adagio shared network drive, on the root of the logical drive L:
L:\Softrak L:\QRASP L:\ASP
It appears that your data and security files are still pointing to the \ASP folder so leave the entire ASP folder on the root of L:
You didn't say but I'm assuming that no one is using Plus for anything at this point in time.
Since you have converted from Plus, you can gas the GLASP, HELP, APASP, MEASP, TBASP folders, and all the leftover trash files accumulating in the root.
There is no reason to keep the plus.exe unless you are using some add-in that is imbedded in the AP or GL folder, but I cannot think of any that would be added. You can confirm that there are no add-ins by viewing the APver.ld4 and GLver.ld4 with notepad.
If you would prefer, cut these files and folders out (that I suggested gassing) and drop into a temporary folder with a date(off the root) for say 6 months and then completely remove.
Regards, Brian
#20717 - 01/28/10 06:29 AM
[Re: Softrak Support]
New Guy
Loc: BC, Canada
Thank you - this worked like a charm - just kept ASP, qrasp and Softrak... and archived the rest just in case.
No, there is no need for plus. Regarding Data - it appears to be in L:\asp\data.
The finance dep't definitely feels virtually cleaner now. I don't think this drive had been cleaned since at least 03ish.
Sorry for taking so long to get back to confirm but circumstances didn't allow.
Jamie
1 registered (1 invisible),
90
Guests and
Spider online. |
14599 Topics
