#20547 - 01/19/10 06:35 AM Print Order Action in OE
Andreas Offline
Heavy Adagio User
Loc: Montreal, QC
Hi there,
trying to add Item Number and BO qty to a new or Order action Default, and it gives me a massage: (Item number highlighted:)
Starting value cannot be greater than the ending value...
can you please assist..
thanks
Andreas
#20548 - 01/19/10 09:17 AM Re: Print Order Action in OE [Re: Andreas]
Hi, Andreas,
What do you have as values in both your Starting and Ending Item Number fields?
For example, if you entered a number or other code as a Starting value but left the Ending value 'blank', you would receive this message.
If you have a 'blank' as the ending value and what you really want is to show the 'last' possible value for an item code, in the Ending fiel, type as many z characters as the field will allow.
#20558 - 01/19/10 11:26 AM Re: Print Order Action in OE [Re: Softrak Support]
Andreas Offline
Heavy Adagio User
Loc: Montreal, QC
Hi I left them as is...from empty to zzzzzzzzz... which should work...
i know i could take an item number to the same item number, but even this does not work...
Thanks for getting back...
A.
#20559 - 01/19/10 11:31 AM Re: Print Order Action in OE [Re: Andreas]
What version of OE are you running? Do your Items use one segment or more than one (as defined in the IC company profile).
There was a known issue with this in an older version of OE and single-segmented item codes, but has been resolved in a service pack, or it may hae been a hot fix. Ensure you have the most current version of OE installed.
#20565 - 01/19/10 12:20 PM Re: Print Order Action in OE [Re: Softrak Support]
Also, if you have the "Remember report settings" option turned on, then turn it off, print the report, and go back and turn it on again.
#20569 - 01/19/10 12:51 PM Re: Print Order Action in OE [Re: Andreas]
Andreas Offline
Heavy Adagio User
Loc: Montreal, QC
thanks, I tried the remeber report settings..didn't change anything...still gives the same message.
...in Item Number i leave the first field blank... (default) and the last field with ZZZZZZZZZ (default)...already explained before..this should work...does not work...
even if i put first item number to first item number..it does not work...
i do not recall a hotfix for this...well i did not receive one.
thanks for getting this done.
Andreas
#20570 - 01/19/10 12:54 PM Re: Print Order Action in OE [Re: Andreas]
As asked in our previous post, what version of OE are you using? Check the Help / About screen for this information.
Hot fixes are not automatically sent out to everyone, as they only fix very specific issues. You should contact your Adagio consultant for this.
#20571 - 01/19/10 12:55 PM Re: Print Order Action in OE [Re: Softrak Support]
Andreas Offline
Heavy Adagio User
Loc: Montreal, QC
I use the latest version OE 8.1C (090731), all my stuff is latest..
Andreas
#20572 - 01/19/10 01:06 PM Re: Print Order Action in OE [Re: Andreas]
Thank you. You need the hot fix dated Sept 2, 2009. This issue was fixed here:
The Order Action report in version 8.1C (2009.07.31) falsely gave the error "Starting value cannot be greater than ending value" when single segment item numbers are used.
#20595 - 01/20/10 08:00 AM Re: Print Order Action in OE [Re: Softrak Support]
Andreas Offline
Heavy Adagio User
Loc: Montreal, QC
thank you, would have liked to get a notice that there is a hotfix out there to apply.
Andreas
