#20338 - 01/08/10 05:22 AM Installing Data Dictionary Exporter problem
Samuel Kopstick Online   content
The client downloaded DDExporterInstall.EXE (i.e. the Gridview docuementation of tables/structures).
However, when we install it, we recieve an error message: "The file k:\softrak\system could not be opened."
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#20339 - 01/08/10 05:36 AM Re: Installing Data Dictionary Exporter problem [Re: Samuel Kopstick]
Vicki Cotton Offline
Loc: Charlottetown, PE
I've just tried to insall and had the same message! Softrak hlp would be appreciated!
#20342 - 01/08/10 06:11 AM Re: Installing Data Dictionary Exporter problem [Re: Vicki Cotton]
GridView should have already installed it in the \softrak's\gvwin subdirectory. Try the download again if it's not already there.
#20346 - 01/08/10 06:40 AM Re: Installing Data Dictionary Exporter problem [Re: Retired_Guy]
The main reason that I want this is because on the Softrak site you advertise that we can generate an Excel spreadsheet that will document the tables and what-not.
How do I generate this spreadsheet?
It sounds like it can be quite useful.
Samuel Kopstick
Toronto, ON
#20348 - 01/08/10 06:51 AM Re: Installing Data Dictionary Exporter problem [Re: Samuel Kopstick]
It is not in the gvwin subdirectory. I've downloaded the file from your website and tried to install but get the error message refereced above - "The file k:\softrak\system could not be opened." We've recently upgraded to AR 9 and we use gridview. I saw in the release notes that this tool would be helpful so wanted to use it becuase some of our gv reports don't work now with the upgrade.
thanks
#20355 - 01/08/10 08:19 AM Re: Installing Data Dictionary Exporter problem [Re: Vicki Cotton]
The 'DataDictionaryExporter.exe' program file must exist in the \softrak\system directory and it cannot be saved anywhere else. Is this where you have placed the file? If not then try copying it there and try loading it again.
To convert GridView views based on AR8 data to use the AR9 dicationary, you need to open each view (ignoring error messages) using GridView 90A. Then open the view definition (press F4), and re-select the table (Receivables 90A). Then GridView will walk you through the rest of the conversion.
There is a tech note in the Partner area of the website with instructions on how to convert GridView views to be based on Receivables 90A data.
#20358 - 01/08/10 08:35 AM Re: Installing Data Dictionary Exporter problem [Re: Softrak Support]
Sorry - Tech Support is right (as usual). DataDictionaryExporter.EXE needs to be in the \Softrak\System directory.
1 registered (Samuel Kopstick), 142 Guests and 2 Spiders online.
14625 Topics
