#20079 - 12/17/09 09:41 AM Error when connecting via remote desktop
Cool Aid Offline
Loc: Victoria, BC, Canada
We have existing users who use a remote desktop connection to a Windows 2003 server to access the Adagio modules. With one of our new users to this process, when we open any of the Adagio modules, we get an error message stating the following:
‘unable to load registration dll’
The mapped drives and permissions seem to be exactly the same for the successful users logging in and the one new one who cannot. We have checked that the existing remote access users can still connect via remote desktop connection and they are able to do so without the above error message.
What does this error mean and how can we correct this problem?
Thank you,
Tanja
#20083 - 12/17/09 10:06 AM Re: Error when connecting via remote desktop [Re: Cool Aid]
Hi, Tanja,
Check to make sure that this user has the same access to the Windows\System32 folder and the files in it that the other users have.
#20115 - 12/21/09 09:12 AM Re: Error when connecting via remote desktop [Re: Softrak Support]
Cool Aid Offline
We have checked the system32 folder and the permissions are the same as the other users. Even when giving the new user full access to the system32 folder, the error message still appears. Is there anything else we can check or try?
Thank you,
Tanja
#20116 - 12/21/09 09:34 AM Re: Error when connecting via remote desktop [Re: Cool Aid]
Hi Tanja,
Is this "new user" running Vista or Windows 7?
#20118 - 12/21/09 09:45 AM Re: Error when connecting via remote desktop [Re: Retired_Guy]
Cool Aid Offline
The new remote user is using Windows XP, which is the same as me and I am able to successfully connect via remote desktop connection.
Tanja
#20128 - 12/21/09 12:33 PM Re: Error when connecting via remote desktop [Re: Cool Aid]
Is your Windows 2003 server a terminal server?
#20137 - 12/21/09 02:19 PM Re: Error when connecting via remote desktop [Re: Douglas Dickie]
Cool Aid Offline
The WIN2003 server is a terminal server.
Our IT Manager is also unable to connect to Adagio via remote desktop and he has full rights and access to everything. He's compared my account permissions and rights to the new user's and they are the same.
The program tries to load but cannot get past the error message ‘unable to load registration dll’.
We're not sure what else to try at this point.
Tanja
#20138 - 12/21/09 02:53 PM Re: Error when connecting via remote desktop [Re: Cool Aid]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
A shot in the dark, but may be worth a look ...
Do you have any type of Internet Security product installed ? Maybe it's the setings for the FW or AV on-access/background scanning that's different ?
Do let us know when you get it solved.
Regards, Pete
Peter Banfield
BAMPH Consulting Services
Barbados
#20139 - 12/21/09 03:03 PM Re: Error when connecting via remote desktop [Re: Cool Aid]
Hi, Tanja,
In that environment, the problem must be a rights issue. All Adagio modules refer to that one file and it is the only one installed on the system. If all of your other users can run Adagio without receiving the error, you need to determine what the difference is between the user that can't run Adagio and the users that can.
You might also want to run ChkSys (located in the Softrak\System folder) while this user is logged on through remote desktop. There is a Check R/W Status button that can be used to determine the user's access to the common Adagio Folders. It's important that you are logged onto the workstation as the Windows user that would be running Adagio when you run ChkSys.
If their rights to the folder are okay, there must be something else that is different with the individual user than the others.
#20140 - 12/21/09 03:04 PM Re: Error when connecting via remote desktop [Re: Softrak Support]
Tanja,
It would be interesting to know the answer to Peter's question also.
1 registered (Howard S.-MMA), 97 Guests and 1 Spider online.
1865 Members
14501 Topics
29 30
