#19740 - 11/21/09 10:38 AM Departmental Summary for a range of departments
Lyndon_Olfert Offline
Loc: Winnipeg
How would you go about editing your Departmental Summary Spec file to show only a specified range of departments? Can this be done using the ColSpec for a department range such as 8000-8999?
Lyndon Olfert, CPA, CGA, CAFM
#19762 - 11/23/09 02:49 PM Re: Departmental Summary for a range of departments [Re: Lyndon_Olfert]
Hi Lyndon,
If you create a Departmental Range within the View Departments screen, this range can be used any place where selection of individual departments is allowed, such as the toolbar, the Department Print or the Statement Group Print functions. You can also select defined department ranges when creating a 'Departmental Comparison' report when dragging an account group to a blank sheet.
Or if you already have a spec set up and you have a department coded directly in the sheet, you can use the 8000:8999 department range to replace an individual department.
#19815 - 11/26/09 05:33 PM Re: Departmental Summary for a range of departments [Re: Softrak Support]
Loc: Winnipeg
I also discovered that with .RangeDept this does not work with department ranges:
'10:10000-*
This does:
'10:10000-`
#19816 - 11/26/09 07:28 PM Re: Departmental Summary for a range of departments [Re: Lyndon_Olfert]
'-*' asks for all departments, regardless of what has been chosen in the drop down. '-`' asks that the 'tick' be replaced by the department drop down. '.RangeDept' should work in either case but still follows these rules.
#19819 - 11/27/09 09:31 AM Re: Departmental Summary for a range of departments [Re: Retired_Guy]
Just to prevent confusion, -` has the backwards apostrophe replaced by the contents of the department drop down. -* does all departments on separate rows.
0 registered (), 92 Guests and 1 Spider online.
14675 Topics
