#19387 - 11/04/09 03:56 PM
POA Integrity Error
POA 8.1A (091029)
We had a Receipt to the wrong vendor in POA, so we changed the Vendor (POA allows this) and posted the Invoice using the right Vendor. Now we have this error in POA's Integrity Check:
2-RC 00002340 has critical error: Actual number of vendors found not equal to number stored in the header file. This data may be corrupt
"Rebuild" is not available (greyed out).
1. Is there a way to get rid of this error?
2. If changing the Vendor causes a Critical error can you disable this ability in POA?
#19390 - 11/05/09 07:10 AM
Re: POA Integrity Error
[Re: SusanTennier]
There is an option in the Company Profile (Interface Tab) which allows you to disallow the changing of a vendor at invoicing.
Ishana Alexander Grant Thornton
#19426 - 11/05/09 05:21 PM
[Re: GT]
Thanks PwC. I unchecked "Vendor Change on Invoice" to prevent this problem in the future. Can anyone tell me if there's a way to get rid of the Integrity error? I have a bunch of new errors in POA Integrity Check today after deleting some obsolete item codes. Can we get rid of the errors?? Rebuild is greyed out and not available. Please help.
1-PO 00001218 has a critical error: IC Item ZZ10Y13S does not exist. 1-PO 00001221 has a critical error: IC Item ZZEX6141R does not exist. 1-PO 00001298 has a critical error: IC Item ZZEX6141R does not exist. 1-PO 00001632 has a critical error: IC Item ZZCARDREADER does not exist. 2-RC 00002089 has a critical error: IC Item ZZEX6141R does not exist. 2-RC 00002159 has a critical error: IC Item ZZCARDREADER does not exist. 2-RC 00002300 has a critical error: IC Item ZZEX6141R does not exist. 2-RC 00002300 has a critical error: IC Item ZZEX5920 does not exist. 2-RC 00002340 has critical error: Actual number of vendors found not equal to number stored in the header file. This data may be corrupt
#19427 - 11/05/09 06:23 PM
[Re: SusanTennier]
I restored from a back up due to the errrors after deleting obsolete item codes, but still need to know if I can get rid of the 1 error:
#19429 - 11/06/09 07:32 AM
[Re: SusanTennier]
Hi Susan,
Use the Toolkit for Adagio to merge all obsolete items into a single item number.
#19439 - 11/06/09 10:04 AM
[Re: Retired_Guy]
Sounds like a good plan! I suppose I can also avoid this in DataCare, "Application Integrity... 795 error(s) Orphan History Records found ................................... FAILED".
BTW, I still need an answer on how to get rid of the 2-RC 00002340 has critical error: Actual number of vendors found not equal to number stored in the header file. This data may be corrupt. Or maybe I can just ignore this error and let it eventually move to history?
0 registered (),
137
Guests and
Spider online. |
14624 Topics
