Page 1 of 3 1 2 3 >
#18928 - 09/30/09 12:25 PM AR Alert Problem
We just noticed today that we lost all alerts on all customers in AR. I assume it happened when we upgraded to AR 9.0A (090511). We have back ups of our data from before the data conversion. Can someone direct me how to get the Alerts from the old data into our current data?
#18929 - 09/30/09 12:27 PM Re: AR Alert Problem [Re: SusanTennier]
Hi Susan,
I can't believe you lost all the alerts. Perhap they aren't turned on or selected to display when expected? The alert model changed extensively in AR 9.0 (alerts by function with the ability to enforce acknowledgement and turn off after display).
#18930 - 09/30/09 12:37 PM Re: AR Alert Problem [Re: Retired_Guy]
I can't believe it either! We didn't notice for a month! Today I was investigating why some of our customers Invoices were not being processed correctly according to the alerts we had set up. It turns out the Alerts are not there. The only Alerts that are currently in AR are recent ones set up since the AR upgrade.
When I do an F6 search in AR using the field Alert? equal to 1, I get 107 results out of our database of 1868 customers. Of those 107 only a handful actually contain active alerts (all very recently added). The remaining have Active Alerts enabled with no contents.
Is there anyway to recover them??
#18931 - 09/30/09 12:39 PM Re: AR Alert Problem [Re: SusanTennier]
In each case, all functions are checked, none require confirmation, none are disabled and contents are empty.
#18932 - 09/30/09 01:39 PM Re: AR Alert Problem [Re: SusanTennier]
Hi Susan,
Could you e-mail me your AR database and a backup (any backup) from before the conversion?
#18935 - 09/30/09 03:46 PM Re: AR Alert Problem [Re: Retired_Guy]
I opened my back up Aug 12/09 (the day before we upgraded to the new AR). I went through the new AR conversion process and the Alerts were there. Now I can't even guess how the alerts were lost?? Using the AR Alerts Messages table, I was able to produce a report with Gridview so I can manually enter these Alerts into our current data.
In the meantime I also opened several back ups from September and all are missing the alerts. I need to go back to the office to get my backup from Aug 13 to see if the alerts are there.
Do you still want my data? It's very large. I can send the AR only if you still want it.
#18936 - 09/30/09 04:12 PM Re: AR Alert Problem [Re: SusanTennier]
Hi Susan,
you've already done what I would do - confirm that they weren't lost during the conversion. The only way to explain the disappearance is through some wired copying of files or perhaps a rebuild from a data integrity problem. Any ideas?
#18938 - 09/30/09 05:10 PM Re: AR Alert Problem [Re: Retired_Guy]
I found something.
On Sept 14, DataCare reported a File Error.
It said:
Adagio Receivables: File Integrity
Control Accounts ... Checked OK
Adjustment Batch Detail ... Checked OK
Adjustment Batch Header ... Checked OK
Customer Alerts ... 1 error(s) found ........................................... FAILED
Summary
File Integrity ... 1 error(s) found ............................................ FAILED
Finshed at: 2009.09.14 18:34
Data Repair Phase
Rebuilding Customer Alerts ... Done
Finished rebuilding integrity errors.
Please repeat Data Integrity Check.
I repeated the Data Integrity check the same night and everything was okay. I figured one alert might have been messed up, but never would have guessed all the alerts in AR would have been wiped out!
This was the first integrity check that we ran after our offices (including workstations and our SBS server) was moved to our temporary office in our back warehouse so our new offices could be built. Maybe a hardware glitch when reconnecting everything?
I just now unchecked DataCare Company Profile/Job Defaults where it says rebuild file and application integrity errors. If I leave these unchecked will it give me an opportunity to repair the errors manually instead of have it wipe out data?
We had further file errors on Sept 22 that said:
Adagio OrderEntry: File Integrity
Sales Order Detail ... 2 error(s) found ........................................ FAILED
Summary
File Integrity ... 2 error(s) found ............................................ FAILED
Finshed at: 2009.09.22 18:33
Data Repair Phase
Rebuilding Sales Order Detail ... Done
Can I look for somewhere for data that might have been lost there??
#18940 - 09/30/09 10:32 PM Re: AR Alert Problem [Re: SusanTennier]
Hi Susan,
The records affected by the DIC are logged in the file xxINTERR.dat. We would never recommend having the rebuild option checked for your nightly backup.
I'm sorry for the work this will cause. If you have that backup (before the repair) then we might be able to get the alerts back for you.
#18941 - 10/01/09 01:11 AM Re: AR Alert Problem [Re: Retired_Guy]
We can manually add back the alerts and at the same time check each of these customers accounts since Sept 14th to see if any invoices were done incorrectly as a result of not having the alerts. Some extra work yes, but we're covered now that I can get a report of the alerts on Sept 13.
ARINTERR.dat and OEINTERR.dat are empty in my current and back up data. Is there a way to see exactly what DIC has done in these "rebuildings"? I'm particularly concerned now about Sept 22 Rebuilding of OE's Sales Order Detail. How can I find out what DataCare did?
Page 1 of 3 1 2 3 >
0 registered (), 44 Guests and 0 Spiders online.
1865 Members
14458 Topics
