#19893 - 12/03/09 11:25 AM Re: Picking Sequences [Re: SusanTennier]
Softrak Support,
Any update on a fix for the Pick Sequences?
Also, on a side note, we would love it the Pick Sequence field would accept more than 4 characters. We very often have the same item in more than 1 location (ie B2, F3, C5). The limitation of 4 characters is too restricting. Is this something that could be limited to more characters in the future?
#20035 - 12/11/09 04:39 PM Re: Picking Sequences [Re: SusanTennier]
A service pack is now available for Inventory 8.1B to show the pick sequence in Item Inquiry. Note that the scenario was something not being correctly saved on the item record, so just installing the service pack will not automatically correct the inquiry problem. You have to go back and re-edit items to ensure they are active at locations, and that will write the required information for the display issue.
Any items added in the future will be correctly set up to display the default picking sequence within Item Inquiry.
We can't change the picking sequence length right now for compatibility reasons, but we are open to considering changes for the future.
#20036 - 12/11/09 05:47 PM Re: Picking Sequences [Re: SusanTennier]
Hi Susan,
Some of the reports are printed in bin sequence (for picking). How can we handle more than a single bin for an item?
#20037 - 12/11/09 09:20 PM Re: Picking Sequences [Re: Retired_Guy]
Hi Softrak Support, Great to hear about the fix. I look forward to receiving the download info in an email.
Hi Andrew, We have always used the Pick Sequence field for more than one warehouse location. An example is that we stock small items in bins for easy picking in section H4. When the bins run low, we restock from master boxes kept in C2. So our pick sequence is H4C2. Sometimes wire and cable takes up several sections so we enter it as B1-7. We've never had it so perfect to have every item on our system in only one section per item.
We have 5000 item codes on our system with 2500 of those with quantites on hand. Whenever we receive product, we update our pick sequence on the system. When a customer places an order, the pick sequence prints on Pick Slips so the product can be easily found. We therefore rely heavily on the pick sequence field being as descriptive and accurate as possible.
I can't think of a report that I've ever printed that I would sort by pick sequence. Occasionally if we're cleaning up a particular section I'll do a search in Inventory of items where the quantity on hand is greater than zero and the pick sequence contains B2.
A little off topic now is that in spite of all of our efforts to organize our product, the system and train our staff, picking errors are still occurring way too often. We have too many similar products with similar model numbers. When we replenish stock the product often comes in with a different model number and we end up with product in stock that is under the same item code and essentially the same item, but with a different model numbers on the box.
I think it may be in our future to integrate a bar code system so we can scan product as it is received, put away and sold. Is there a way to implement a bar code system with our Softrak software?
#20039 - 12/12/09 09:15 AM Re: Picking Sequences [Re: SusanTennier]
Hi Susan,
It's called warehouse management and comes from RF Pathways, but it's not cheap. 10 people saying "barcoding" have 10 different ideas of what that means.
Having said that, it's part of the "scope" discussion for future changes to Inventory. Of course, you're also talking about changes to OE and POA too, so this is a significant amount of development.
#24102 - 09/22/10 07:55 PM Re: Picking Sequences [Re: Retired_Guy]
Vlad Maksymiv Offline
Adagio ADP
Loc: Toronto, Canada
Dear Susan,
Are you still interested in "bar code system" for Adagio ?
My company specializes in developing mobile applications for Adagio.
I think I might have a solution for your business: "Warehouse Management for Adagio Accounting"
Please visit http://lenmax.com/wms.html to find more.
Vlad Maksymiv
www.lenmax.com
3 registered (Samuel Kopstick, Warren Karges, 1 invisible), 49 Guests and 3 Spiders online.
14668 Topics
