I notice that when we run our daily DataCare backup job that it is not only putting a copy of the zip file in C:\BackUp as I have it set to in DataCare/File/BackUp/BackUp Options. It is also leaving a copy of the zip file in I:\Data. I don't think we really need a duplicate copy of every back up stored in I:\data. Is there a way to have the zip file only go to C:\BackUp and not to I:\Data?
Here is the job report:
Data Integrity of: Located on: I:\data\ with extension: dat Started at: 2009.05.28 18:15 by Susan Tennier Job: BACKUP
Backup of: Backup file: I:\Data\DCB642.ZIP Backing up data at: I:\data\ with extension: dat Backing up data with prefix: AP AR GL IC IR OE SR Backup started at: 2009.05.28 18:15 by Susan Tennier Backup copied to C:\backup\DCB642.ZIP. Backup completed ... OK Backup finshed at: 2009.05.28 18:17
Summary
Data integrity check was complete with no errors.
Finshed at: 2009.05.28 18:17
Softrak Support
Hi Susan,
In the DataCare company profile on the Backup tab, there are 2 backup directories, the main one and the copy. Remove the copy and set the main backup to the location you require.
Regards, Softrak Tech Support
