#16889 - 04/21/09 05:35 PM Error installing Adagio Receivables 9.0A
Apex Offline
Adagio Groupie
Loc: Cranbrook
Program does not start up error reads The dynamic link library PEGRPDS.DLL could not be found in the specified path.....L:\softrak receivables c|winnt....so on so on....
I installed this as per usual on a computer in the server room it updates the files on the server, as I have for all installs then go around and do the workstation upgrade on the 3 accounting computers, but it comes up with this error.
Aaron McArthur
Apex Computer Services
Cranbrook, B.C.
#16890 - 04/21/09 05:44 PM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Did you install the Receivables upgrade directly at the server? Or from a workstation connected to your server. The first option is incorrect and the second option is the correct way.
The file above should get installed to the X:\softrak\receivables program directory. If you look there with Windows Explorer, do you see the file?
What version of Windows is on your workstation?
#16898 - 04/21/09 08:55 PM Re: Error installing Adagio Receivables 9.0A [Re: Softrak Support]
Apex Offline
Adagio Groupie
Loc: Cranbrook
I did the install, same as usual. I did not do it right on the server. Did it on a workstation in the server room it runs windows 2000, will check to see if I can see that file in the morning.
I had a problem with the first install of 9.0A, I had to uninstall it and reinstall it to do the workstation upgrade.
Aaron McArthur
Cranbrook, B.C.
#16899 - 04/21/09 10:40 PM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Receivables v9 does not support Windows 2000. This may be your problem.
#16902 - 04/22/09 11:01 AM Re: Error installing Adagio Receivables 9.0A [Re: Douglas Dickie]
Apex Offline
Adagio Groupie
Loc: Cranbrook
Is this really true that receivables 9.0A will not work on a Windows 2000 computer?????
Aaron McArthur
Cranbrook, B.C.
#16903 - 04/22/09 11:54 AM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Receivables 9.0A was not tested for compatibility with Windows 2000 other than cursory tests to see if it appeared to install and run. It did. Beyond that Softrak makes no guarantee of compatibility. Please see http://www.softrak.com/products/compatibility/compatibility.php for a statement on Windows 2000 compatibility.
The problem may be caused by a missing Microsoft DLL. You can try finding a copy of gdiplus.dll on the machine or another machine and copying it into \softrak\receivables. If that does not work copy it to \winnt\system32. If that does not work we can’t help any further.
#16904 - 04/22/09 12:07 PM Re: Error installing Adagio Receivables 9.0A [Re: Softrak Support]
Apex Offline
Adagio Groupie
Loc: Cranbrook
we have 3 computers in the accounting department. 2 are windows 2000 and the other is XP. I thought i would try do the workstation the allwkst upgrade on the xp computer but came up with the same error.
Aaron McArthur
Cranbrook, B.C.
#16905 - 04/22/09 12:36 PM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Apex Offline
Adagio Groupie
Loc: Cranbrook
we have reinstalled the previous version 8.0B, and seems to be working fine, the only thing is in Adagio Receivables when its open along the headers at the top if you click on Adagio it opens up and Adagio Payables and Adagio Gridview are there on the drop down list, but no Adagio Ledger. Is there a way to fix this. Is this a problem?
Aaron McArthur
Cranbrook, B.C.
#16906 - 04/22/09 12:49 PM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Apex Offline
Adagio Groupie
Loc: Cranbrook
sorry the receivables 8.0B does not work... the accountant came up with these errors.
Invalid record batch file
Error retrieving batch ARALBTCH
your data may be damaged.
Aaron McArthur
Cranbrook, B.C.
#16907 - 04/22/09 01:06 PM Re: Error installing Adagio Receivables 9.0A [Re: Apex]
Did you manage to convert (any or all of) the data to AR 9.0A? If so, then you'll have to roll the data back to version 8.0B as well as the programs.
BTW - AR9.0A requires Ledger V9.0A at least, and V9.0B if you are going to make use of the feature to record a difference accounting data than the transaction date.
0 registered (), 162 Guests and 2 Spiders online.
14672 Topics
