#16247 - 03/05/09 05:37 PM OE order import and tax calculation
Victor B. Offline
Loc: Toronto, ON, Canada
After importing customer orders into Adagio OE Datacate generates errors (please see example)
Adagio OrderEntry:
Application Integrity
Document O 161401 total of tax 0 does not match calc 58.66
Document O 161406 total of tax 0 does not match calc 30.49
Orders/Invoice headers ... 38 error(s) found
It appeared the total tax amount calculated on line items (Details order tab) does not equal to Tax amount (Total order tab).
My questions are:
1. What happened to data when DC does the following?
Correcting Phase 2 Errors
*** Document O 161401 tax has been adjusted
*** Document O 161406 tax has been adjusted
2. What should be done in order not to have tax related DC errors?
Thank you
Victor
Victor
#16254 - 03/06/09 11:08 AM Re: OE order import and tax calculation [Re: Victor B.]
Hi, Victor,
When DC is rebuilding the errors it is changing the tax to what has been calculated.
If you want to avoid these types of errors, make sure the 'Calculate tax on' setting in your Company Profile is set to 'Detail line', rather than by total. The rounding will be more accurate.
#16266 - 03/09/09 09:13 PM Re: OE order import and tax calculation [Re: Softrak Support]
Victor B. Offline
Thank you,
Could you please be more specific: If 'Calculate tax on' set to order total which tax amount DC is changing and which amount is concidered as the 'tax calculated'.
Thank you again
Victor
Victor
#16269 - 03/10/09 11:28 AM Re: OE order import and tax calculation [Re: Victor B.]
Hi, Victor,
If the setting is for 'Detail line', tax is calculated for each detail line and rounding is done accordingly.
If the setting is for 'Totals', the tax and rounding is done on the total taxable order and the rounding might not be the same as what is calculated for each detail line.
#16274 - 03/10/09 08:30 PM Re: OE order import and tax calculation [Re: Softrak Support]
Victor B. Offline
Thank you
Victor
Edited by Victor B. (03/10/09 08:30 PM)
Victor
1 registered (1 invisible), 119 Guests and 11 Spiders online.
14579 Topics
January
