#14668 - 10/06/08 06:12 PM
Posting disallowed
Hello All,
I have a client whom is accessing Adagio in a server environment, but is having an issue with Invoices.
When they go to post Invoices from one computer on the server, a message comes up saying that they are using an invalid data path and a reference to 1212, which is a clearing acct. they use. However, of course the path should be correct as they are able to access the same data everyone else is getting into, just a hang up with the post function. All other functions as well as reports seem to be fully accessible.
Anybody have any similiar issues or ideas???
D/C
#14672 - 10/07/08 11:25 AM
Re: Posting disallowed
[Re: Softrak Support]
Hello Softrak
You are correct, the error message starts with "Critical Error 1212." They have just started seeing this error in the past few days.
There was a recent install done by the client of Adagio Invoices only(they had a tower replaced).
The other computers on the network are able to perform the posting of Invoices just fine, witht eh same mapping.
What would be the likely cause of the \softrak\dict directory issue??
Let me know if you need any more info
D/C
#14675 - 10/07/08 01:05 PM
Softrak,
Thanks for the speedy reply. The client is using Invoices 8.1 2007.09.21.
They tried going in through the QIWIN.EXE file and they were able to post their invoices on the troubled machine that way.
Should they keep enetring Invoices via that route or is there something else we should have a look at??
D/C
#14717 - 10/08/08 07:19 PM
Darcy:
Also check that the properties of the shortcut use the mapped drive to start Adagio, not the UNC. I have found that the workstation install when run in Vista sometimes makes the path to the program "\\server\\resource\\softrak\...etc" instead of "x:\softrak\..etc."
0 registered (),
385
Guests and
Spiders online. |
14617 Topics
