#14207 - 08/28/08 12:25 PM AR Terms - are they sufficient
We are trying to determine if the Due date calculations currently in Adagio Receivables are sufficient for managing the different types of due dates and discount dates our customers are using or that are common in their specific industries.
If you grant payment terms or early payment discounts to your customers, have you been able to automate those terms using the current calculations available in Adagio Receivables? If not, what type of payment terms (not installment receivables) are you granting and how do you calculate them from the invoice date?
Thanks for any and all feedback.
#14214 - 08/28/08 04:34 PM Re: AR Terms - are they sufficient [Re: Retired_Guy]
Kate Spontak Offline
Loc: New Jersey
Dating terms.
Payment will be due on a specific date. Date does not change relative to Invoice date. Usually a new date will be assigned for each season - i.e. Due date might be 12/15/08 for goods shipped 9/15/08 to 11/30/08. Usually subject to a credit limit, and customer can purchase more by paying for past shipments.
Allows small retailers to purchase ahead for the season. Easier for vendor to manage inventory and shipments by spreading seasonal purchases out.
Kate Spontak
New Jersey, the Garden State
#14216 - 08/28/08 05:09 PM Re: AR Terms - are they sufficient [Re: Kate Spontak]
Hi Kate,
OK - we've had a couple of requests for this. Should we just store the month/day and assume that the year will always be such that it is in the future? Or would a specific date be better (which might result in invoice due dates in the past and unexpected aging results)?
#14229 - 08/29/08 02:39 PM Re: AR Terms - are they sufficient [Re: Kate Spontak]
Hi Kate:
I had the same request from a client recently for the same reason.
Andrew had a suggestion that serves our client well. You may already know this but it was news to me!
If the Terms code on the Order/Invoice header is left blank, you can enter any Due Date that you want. It's not as good as a special Terms code because it relies on the user, but it works in most cases.
#14279 - 09/02/08 04:31 PM Re: AR Terms - are they sufficient [Re: Bruce Gardner]
Loc: New Jersey
Thanks for the tip, Bruce.
Andrew,
Assuming the year in the future would be fine. Usually dates are up to several months out but not more than that.
Kate Spontak
#14334 - 09/05/08 10:02 AM Re: AR Terms - are they sufficient [Re: Retired_Guy]
MLS Offline
New Guy
Is this something others have had requests for?
We have been asked for aging to the end of x months rather than just the end of the next month which currently exists.
Using existing options and adding 60 or 90 days will result in a day or two either side of the actual month end date which is not the desired result.
The previous posts touch on this to some extent but do not resolve the issue completely.
Frank VanderGriendt
Stief Group, Waterloo, ON
800.540.3164
#14335 - 09/05/08 10:09 AM Re: AR Terms - are they sufficient [Re: MLS]
Hi Frank,
Would the addition of date fields for entry of the aging days (so that you could see the dates being selected), be a reasonable improvement?
#14336 - 09/05/08 10:21 AM Re: AR Terms - are they sufficient [Re: Retired_Guy]
MLS Offline
New Guy
That sounds like a reasonable solution Andrew.
When you say date fields do you mean a pop-up calendar? Some people are not so good at determining month end dates without visually seeing the calendar.
If so I might suggest only being able to move forward or back month by month so as to avoid aging years in advance by mistake.
Frank VanderGriendt
800.540.3164
#14337 - 09/05/08 12:40 PM Re: AR Terms - are they sufficient [Re: MLS]
Hi Frank,
Yes - a pop-up calender as in all other Adagio dialogs. You'd could choose either the number of days or a secific date. Selecting one would change the other, so you'd notice 400 days in the future.
#30868 - 02/10/12 07:42 AM Re: AR Terms - are they sufficient [Re: Retired_Guy]
Warren Karges Offline
Did this get set aside?
I have a client that has similar invoicing practices as Kate described, they would prefer not to have to have to remember to edit the due date so often. Being able to select a calendar day rather than have it relative to the invoice date would make them very very happy!
Warren
1 registered (Tanya_Belanger), 198 Guests and 6 Spiders online.
14576 Topics
