#13472 - 07/08/08 11:56 AM Corrupt Data - Damaged Index - Revisited
We are having continual problems with damaged data. We have 20 Lanpaks, 9 XP Pro workstations on SBS 2003 server, all hardware meets or exceeds the Softrak minimum requirements. We have a gigabit lan. We're running DC 8.1A(071220), IC 8.1A(070825), Ledger 9.0A(080402), OE 8.1B (080326), AP 8.1A(070919), AR 8.1A(070920), SA 8.1A (080107), GV 8.1A (071008), POA 8.0 07-May-2008, Paymate Acclaim 5.50 July 2008. Just about every week, sometimes a few times a week, we are all working away when suddenly the data becomes corrupt (can't scroll through items or customers, items or customers repeated in the scroll window, etc). We then get everyone off of Adagio and run a DataCare integrity check where multiple errors are found. We rebuild the errors (what other choice do we have?) and the rebuilding process strips a bunch of our shipping addresses. I can't say specifically what might be causing these problems. We are not doing anything unusual. Occassionally we might have deleted a customer or an item. POA was often in use on the day of the errors. However, I can't really pin point if it's any one thing since we use all the software in many ways every day and there's nothing different we are doing on the particular days when the data becomes corrupt.
Is anyone else experiencing data corruption? Has anyone ever successfully fixed this problem?
Please advise.
Summary
File Integrity ... 110 error(s) found .......................................... FAILED
Application Integrity ... 34 error(s) found .................................... FAILED
Finshed at: 2008.07.08 10:34
Data Repair Phase
Rebuilding Items (1) ... Done
Correcting Phase 2 Errors
*** Customer must be manually corrected for document I 179897
*** Customer must be manually corrected for document I 179903
*** Item line must be manually corrected for document I 179904
*** Item line must be manually corrected for document I 179905
*** Item line must be manually corrected for document I 179907
*** Customer must be manually corrected for document I 179915
*** Customer must be manually corrected for document I 179917
*** Item line must be manually corrected for document O 155488
*** Customer must be manually corrected for document O 175510
*** Customer must be manually corrected for document O 177182
*** Customer must be manually corrected for document O 178986
*** Customer must be manually corrected for document O 179674
*** Customer must be manually corrected for document O 179773
*** Item line must be manually corrected for document O 179773
*** Customer must be manually corrected for document O 179775
*** Customer must be manually corrected for document O 180026
*** Customer must be manually corrected for document O 180117
*** Customer must be manually corrected for document O 180176
*** Customer must be manually corrected for document O 180186
*** Customer must be manually corrected for document O 180262
*** Item CO CNF302Z OnSales Order was adjusted at loc WA
*** Item CO CMP6 ShipNotCosted was adjusted at loc KI
*** Shipping address EL9742 for customer has been removed.
*** Shipping address FE8843 for customer has been removed.
*** Shipping address FE8843 for customer AJAX has been removed.
*** Shipping address FE8843 for customer BARRIE has been removed.
*** Shipping address FE8843 for customer CHATHM has been removed.
*** Shipping address FE8843 for customer COBORG has been removed.
*** Shipping address FE8843 for customer LONDON has been removed.
*** Shipping address FE8843 for customer PETERB has been removed.
*** Shipping address FE8843 for customer WOODBR has been removed.
*** Shipping address FL3737 for customer 1 has been removed.
*** Shipping address FM7006 for customer has been removed.
*** Shipping address GO0093 for customer has been removed.
Rebuilding Customers ... Done
Rebuilding Customers Extension ... Done
Finished rebuilding integrity errors.
Please repeat Data Integrity Check.
#13474 - 07/08/08 12:12 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Hello Susan,
Please install the OE Service pack (080421). You are on an older version and on an upgrades plan.
#13476 - 07/08/08 01:00 PM Re: Corrupt Data - Damaged Index - Revisited [Re: Softrak Support]
I just installed the service pack so I am completely up-to-date now (I must have missed it before). I also realized a WAY easier way to get all the shipping addresses back. I opened up the data in OE from last nights back up and exported the shipping addresses. Then imported them into the repaired current data today. Saved a ton of time.
I would still like to know if there is a solution to this problem. Thanks.
#13477 - 07/08/08 02:53 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Hello Susan,
Now that the Service Pack has been installed, please let us know if the problem reoccurs.
Also, are you checking OrderEntry separately from Receivables? Many of the OrderEntry errors are related to the Receivables errors. If you are, please check and rebuild any errors in Receivables prior to checking OrderEntry.
#13479 - 07/08/08 03:19 PM Re: Corrupt Data - Damaged Index - Revisited [Re: Softrak Support]
Yes the problem recurred already. This time the errors were only in Inventory and OE. However, we also lost a cash batch in AR somewhere along the line today that is now being reenterred manually. We have no idea if anything else has been lost. There were 50 or more invoices enterred today, plus a few new inventory items, new POs, receiving, etc.
I will try next time to check the integrity in AR and IC before checking OE. We need to get this resolved somehow. Please help.
Summary
File Integrity ... 6 error(s) found ............................................ FAILED
Application Integrity ... 12 error(s) found .................................... FAILED
Finshed at: 2008.07.08 14:24
Data Repair Phase
Rebuilding Items (2) Additional ... Done
Rebuilding Item (3) Extension ... Done
*** Item line must be manually corrected for document I 179928
*** Item line must be manually corrected for document O 155504
*** Item line must be manually corrected for document O 178207
*** Item line must be manually corrected for document O 178610
*** Item line must be manually corrected for document O 179324
*** Item line must be manually corrected for document O 179763
*** Item line must be manually corrected for document O 180351
*** Item line must be manually corrected for document O 180352
#13480 - 07/08/08 03:39 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
doswalt Offline
Loc: AL
Did someone delete an item? Your first post mentions deleting items and customers.
If someone is deleting shipping address and inventory items, 1 deletion could turn into 20 or 30 errors that deletion is referred to.
David
Edited by doswalt (07/08/08 03:44 PM)
#13481 - 07/08/08 03:52 PM Re: Corrupt Data - Damaged Index - Revisited [Re: doswalt]
Noone deleted any items today. Some new items were added however. No one added, changed or deleted any shipping addressess today. Once customer was deleted last night which I followed up with a data integrity check.
Just to confirm, this is not an error in Adagio because of a deleted item or customer referenced in an old invoice. This is full blown data corruption / damaged index.
#13482 - 07/08/08 05:06 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Hi Susan,
There's a hardware issue somewhere in your network. Unfortunately, these can be difficult to track down. The easiest way is to write batch file that does nothing but copy information up and down your network (from a workstation to the server and back). You need to have a "whole bunch" of little files, a one or two really large files in the directory you copy around and around. Have the batch file end by calling itself and let it run all night.
The next morning, use the DOS file compare utility (FC) to compare the contents of all the files you've been copying to the original. If there are ANY differences, then you've isolated the problem to the workstation/server you were testing.
Are any of your workstations "hanging" while in Adagio (or any other application)?
#13486 - 07/09/08 12:34 AM Re: Corrupt Data - Damaged Index - Revisited [Re: Retired_Guy]
I created 2 folders with 700 files each and made a slight difference in one file. In DOS I entered: FC c:\test1\*.* c:\test2\*.*
It finds the difference in the one file that I modified, however, the buffer in the DOS window holds only the last 100 or so records. So 600 hundred file results scroll past and are therefore no longer available. Is there a way to check all these files and get a summary at the end? I really only need to see the results of any discrepencies.
#13491 - 07/09/08 01:32 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Hi Susan,
OK - here's the command you need to use to compare the two sets of files. First, make sure that your current directory is the original file set. The carefully type:
Code:
for %a in (*.*) do fc /b %a c:\test1\%a >>c:\x.txt
You'll see the computer do a binary file compare for each file in the directory. When it finishes type:
Code:
notepad c:\x.txt
to see the results of the comparisons. They should all look something like:
Code:
Comparing files glfrstim.xls and \TEST1\GLFRSTIM.XLS
FC: no differences encountered
Comparing files GLFSET'1.sam and \TEST1\GLFSET'1.SAM
Comparing files GLFSET'2.sam and \TEST1\GLFSET'2.SAM
Comparing files GLFSET'R.sam and \TEST1\GLFSET'R.SAM
unless there is a difference in which case you might see something like:
Code:
Comparing files GLGLOB.SAM and \TEST1\GLGLOB.SAM
00000002: 09 03
Comparing files GLGROUP.sam and \TEST1\GLGROUP.SAM
which highlights a difference between two bytes in the file. Since all you've done is copy data files around the network, there should be any differences between the copied files and the reference set.
OK?
#13493 - 07/09/08 01:48 PM Re: Corrupt Data - Damaged Index - Revisited [Re: Retired_Guy]
I'm taking a close look at our server as the possible source of the problems. Softrak's website states specific system hardware requirements for Workstations but only software recommendations for the server. Our server is an Acer G330 with a Pentium Dual Core D 925 3.0GHz, dual 250GHz Hard Drives, 4GB Ram, DVDRW, Video on board. Is this sufficient for our Adagio usage?
Please advise.
#13500 - 07/09/08 02:48 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Looks OK to me, but our Partners might have more insight. What are you using as an operating sysem on the Server?
#13503 - 07/09/08 02:56 PM Re: Corrupt Data - Damaged Index - Revisited [Re: Retired_Guy]
Windows Small Business Server 2003 with XP Pro Workstations.
#13505 - 07/09/08 03:03 PM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Is your server only dealing with Adagio, or is it also your e-mail (Exchange) Server and Internet gateway? Also, other than when you are working from home, do the workstations use Terminal Server to run Adagio?
Edited by Andrew Bates (07/09/08 03:04 PM)
#13506 - 07/09/08 03:26 PM Re: Corrupt Data - Damaged Index - Revisited [Re: Retired_Guy]
YES our server is used for Adagio and email Exchange and for other data (i.e. Word and Excel documents).
NO our server is not used for an Internet gateway.
All of our workstations are running locally to the server and NOT using terminal server. The Adagio data corruption is occurring during the day when everyone is running locally. I use terminal server occasionally in the evenings when I log in remotely from home using Windows Remote Desktop Connection.
#13582 - 07/16/08 09:45 AM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Update - Our motherboard was crashing periodically (not necessarily crashing while Adagio was in use and Adagio wasn't necessarily becoming corrupt immediately following a server crash). So, we never put 2 and 2 together, none-the-less, in order to eliminate any and all possible causes for the Adagio data corruption, we changed the motherboard on the server and fully tested the ram etc. Also updated all systems to current drivers and services packs etc. Everything seems to be good now. DataCare is running faster too, even across the server. I'm hoping that the whole issue may have been caused by a flaky motherboard on the server. Time will tell.
#13585 - 07/16/08 11:56 AM Re: Corrupt Data - Damaged Index - Revisited [Re: SusanTennier]
Ralph Allan Offline
Susan,
Good work tracking this down. Intermittent problems are the most frustrating ones to diagnose and resolve.
Ralph Allan
Business Computer Centre
Prince George BC Canada
