#12543 - 05/02/08 05:21 PM Adagio Inventory 'Items Status' report
Andre Kuehnemund Offline
Loc: Emeryville, CA U.S.A.
It's not working. All the other reports appear to be working, but when we run this one, a new blank window flashes on the screen for a split second and then it's gone. We're then back at the selection screen. Has anyone else seen this? Any ideas as to how to fix it?
Andre
#12546 - 05/02/08 06:13 PM Re: Adagio Inventory 'Items Status' report [Re: Andre Kuehnemund]
Usually this behaviour in a report is because the report tables did not get updated properly, or they're on the wrong drive (which is really saying the same thing).
Does \softrak\system\chksys.exe report anything unusual?
#12548 - 05/02/08 07:03 PM Re: Adagio Inventory 'Items Status' report [Re: Retired_Guy]
Andrew's reason is the most likely cause. Or the table could be OK and the report file itself is out of synch. Do you have a \softrak\icwin\modrp directory with any reports?
Another possible reason is uncleared temporary files - try cleaning those out of Windows.
Did this just start happening or has there always been a problem? When did you last install an Adagio IC upgrade?
What selections are on the report?
Does your IC data pass an Integrity Check?
#12566 - 05/05/08 04:37 PM Re: Adagio Inventory 'Items Status' report [Re: Softrak Support]
Fong Offline
Adagio Ace
How do you clear the temporary files? I have problm with the Item Valuation Report because of these temp files.
2 registered (Samuel Kopstick, 1 invisible), 90 Guests and 3 Spiders online.
14527 Topics
