#11624 - 03/05/08 11:22 AM
order entry error message
Loc: langley
starting this morning the use of F6 tab to look up a customer gives the error below. This started when we had a slow remote connection. It now happens for all users regardless of security level or location. looks to be only OE module Insufficient rights to create file in data directory
This used to be a problem when the CRF files were too many... that has been fixed. I see no crf files at all in the data base.
#11661 - 03/06/08 06:28 PM
Re: order entry error message
[Re: Softrak Support]
Adagio Prodigy
Loc: Langley
That is definitely not the problem, as everyone has and uses their own ID.
Additionally, we have another data set, which uses the same information, that we do "testing" in. This data set was last overwritten in mid-February, and I went into that data set today, it is fine.
So I believe something (don't know what) is definitely "missing" from our data. I did double check, and it is indeed only OE. All other modules the F6 key works fine. As Bruce mentioned, this problem began when the system was responding extremely sluggishly.
#11698 - 03/10/08 01:14 PM
[Re: Barb9]
Adagio Prodigy
Loc: Langley
We are still experiencing this problem. Any help?
Thank you.
#11705 - 03/10/08 02:19 PM
[Re: Barb9]
Hi Barb,
What application has F6 stopped working in when looking up customers? (OrderEntry or Receivables). Do both applications pass the Data Integrity Check? (File | Data Integrity Check) If you can press F6 without generating the error, try clicking the Reset button in the Column Editor, exiting the column editor, then re-selecting the columns you'd like to have displayed.
#11718 - 03/10/08 07:00 PM
[Re: Retired_Guy]
Adagio Prodigy
Loc: Langley
Okay, tried suggestions. Did a DI check in O/E and in inventory. Both came up clean. The problem is really only in O/E, and it is consistent right across the board for all our users. If any of us go into O/E, click "New" to enter a new order, then, at "Customer" hit the F6 button, we all get the same message: "Critical Error: (1011) insufficient rights to create file in data directory."
Cannot access the column grid at all to try the second suggestion of resetting the column Editor.
Thanks for the continuing suggestions, I know we are going to fix this and make everyone happy. Some of our users are quite dependant on this function to get the right customer. Work around is putting in three letters, then 000 and arrowing down. You would be surprised how some people STILL want their F6 key!
Thanks very much. I will try to be patient!
#11721 - 03/10/08 07:35 PM
[Re: Barb9]
Hi Barb,
Go into the data file and search for OEF???'?.dat where "dat" is your data extension. (It is often easier to do this from the command prompt.) If you are sure that no one is in OrderEntry, rename all the files that have numbers in the first 3 "???" position. That is:
Delete OEF001'I.dat and OEF001'R.dat but not OEFCTL'R.dat.
My guess is that you'll find one of the temporary numeric files with 'I but not 'R or vice versa.
#11739 - 03/11/08 02:29 PM
[Re: Retired_Guy]
Adagio Prodigy
Loc: Langley
Andrew, I checked our data file and the following three OEF files exist:
OEF001'I.DAT OEFCTL'I.DAT OEFCTL'R.DAT
Given that there are both the I and the R, what is the best way to proceed?
Thanks VERY much for the help!
#11742 - 03/11/08 02:48 PM
[Re: Barb9]
It's the OEF001'I.DAT that's causing the problem. Get rid of it.
1 registered (Softrak Support),
44
Guests and
Spiders online. |
14598 Topics
