#11814 - 03/14/08 02:46 PM Invalid Pointer Operation
Tony Martin Offline
Loc: Chatham, Ontario, Canada
My customer is getting this error repeatedly in Order Entry since upgrading to 8.1A (070826).
It normally occurs while creating invoices and appears to be non-fatal.
Any ideas?
Tony Martin
Code 6 Programming
519.359.0918
#11815 - 03/14/08 02:49 PM Re: Invalid Pointer Operation [Re: Tony Martin]
Does the data pass the DIC? Where (specifically) does the error occur? Does CHKSYS report any problems with the install?
#11816 - 03/14/08 02:54 PM Re: Invalid Pointer Operation [Re: Retired_Guy]
Tony Martin Offline
DIC - OK
CHKSYS - OK
This client has >1Gb database with 75,000+ inventory items, I'm wondering if this is a network timeout issue similar to the 'exception reading...' errors.
Tony Martin
Code 6 Programming
519.359.0918
#11822 - 03/14/08 04:16 PM Re: Invalid Pointer Operation [Re: Tony Martin]
Tony Martin Offline
The error occurs immediately after printing an invoice...
Tony Martin
Code 6 Programming
519.359.0918
#11823 - 03/14/08 04:22 PM Re: Invalid Pointer Operation [Re: Tony Martin]
doswalt Offline
Loc: AL
Are you printing from the Preview screen or using the Print funciton?
#11824 - 03/14/08 04:27 PM Re: Invalid Pointer Operation [Re: Tony Martin]
Hi Tony,
Did a search, and nobody else has reported this error. Is the 'invalid pointer' error the first error that occurs, or was there another one that happened first? Sometimes this error can be a symptom of a problem further up the chain.
Does 'repeatedly' mean every time or frequently or often enough?
Is this a problem for all users, or only some?
Does print preview give the same error? Print/Fax/Email?
Printing from Current or Historical invoices?
Printing from the grid or the Print Invoices function under Maintenance, or both?
Do all invoices specifications have the same problem, or just the one in use?
Does sample data have the problem?
#11827 - 03/14/08 05:02 PM Re: Invalid Pointer Operation [Re: Softrak Support]
Tony Martin Offline
Some answers...
'Repeatedly' means 'Often enough to be annoying'
Only one user has reported this problem, but this is the only user with volume.
Print preview is fine.
Printing from current invoices.
Printing from the grid window.
All invoice specs display same problem.
Have yet to test sample data, now 5:02pm on Friday...
...it's 'Miller Time' !
Tony Martin
Code 6 Programming
519.359.0918
1 registered (accountability), 115 Guests and 1 Spider online.
