#11757 - 03/12/08 03:54 PM
Adagio Ledger V9.0A (080307) Service Pack Released
As mentioned in today's Adagio Ledger webinar, there is a new Service Pack available for all users of Adagio Ledger V9.0A. You can find the details of all the changes by reading the release note, but here are the highlights: - The View Accounts grid can now be sorted in Dept/Account order as well as the standard Account/Dept sequence. Right mouse click on the Column titles to select the sequence you want.
- There is a new Condensed option on the G/L Detail Listing which results in a printout that more closely resembles that from earlier releases.
- The problem of the hidden "Posting complete" message has been fixed.
- The handling of the Y/E Adjustment bucket in the financial reporter has been improved and now allows printing of a final year end Income Statement that ties to the Balance Sheet.
We strongly encourage you to download and install this Service Pack as it includes all the prior fixes to the product released in earlier months. For those of you waiting for these fixes, we appreciate your patience.
#11767 - 03/12/08 08:46 PM
Re: Adagio Ledger V9.0A (080301) Service Pack Released
[Re: Retired_Guy]
Hi Andrew
When I installed the Service Pack today, it slowed down tremendously when it reached the sample data installation - if I let it proceed, it would have taken hours. I ended up ending the task, and immediately re-installing. It worked fine the second time, although it skipped the sample data installation. I guess it thought the files were already installed when in actuality only a few were installed before I aborted.
Tech support tells me that they confirm this and that it is an anti-virus issue, and that I should exclude the *.SAM and *.AMC files from my anti-virus checker.
I don't like this answer, for a variety of reasons, including that it involves fiddling in areas where most of my clients aren't comfortable.
I think you should either: a) strongly recommend disabling anti-virus before installing the Service Pack, b) recommend skipping the sample data install if anti-virus software is detected, or c) rework your install routine to avoid this problem, somehow.
PS - I don't know if you can change a subject, but the official date of the Service Pack is 080307.
#11769 - 03/12/08 09:14 PM
[Re: Steve Schwartz]
Hi Steve,
Thanks for the heads up. We don't really have much control over this, and we certainly can't disable the anti virus checkers. Insofar as your clients are not familiar with excluding a set of files, surely they are just as unfamiliar with disabling the checking entirely.
There's no specific reason to (re)install the sample data with the service pack.
#11819 - 03/14/08 02:14 PM
Hello Steve,
After testing this pretty extensively, this is what we have found:
When installing the GL 9.0A (2008.03.07) Service Pack (but not a full product or upgrade) and you are running McAfee anti-virus software, if you elect to install the sample data the install performance may become extremely slow. If this happens you will need cancel the install and temporarily disable the On-Access anti-virus scanning. Then start the install again. Remember to re-enable your anti-virus checking after the install of the sample data completes.
We have not seen the problem with AVG, so it might just be a McAfee issue.
#11820 - 03/14/08 02:17 PM
[Re: Retired_Guy]
Loc: Winnipeg
The same delay happened with us. We have the network version of AVG AntiVirus Software.
Lyndon Olfert, CPA, CGA, CAFM President - Aboriginal Strategies Inc.
#11828 - 03/14/08 05:03 PM
[Re: Lyndon_Olfert]
Hi Lyndon,
Thanks for the info. Maybe it was some change made by a Windows Update. We do not know what is going on.
All feedback appreciated.
#11838 - 03/15/08 12:35 PM
[Re: Douglas Dickie]
Hi Doug,
As far as we can determine, once you have cancelled and restart the process, the workstation "learns" something about the install and no longer hangs trying to copy the sample data. So, once you've seen the problem and cancelled, you won't see it again on that workstation. This makes testing to track down the problem very difficult.
#11840 - 03/16/08 08:10 AM
[Re: Retired_Guy]
Loc: Calgary
I had the same problem - running stand-alone version of AVG AntiVirus Software.
Carol Wojick CW Consulting
14623 Topics
