#11523 - 02/27/08 04:47 PM Interest Charges in Receivables
Sandra Offline
Loc: Vancouver
I have a situation where I would like to backdate an interest charge against an old outstanding receivable. When I run the interest calculation against the sample data it appears to default to 1 month of interest. Is there any option I can select that will calculate the interest back to the original due date or should I calculate manually and edit the batch?
Thank you for any and all advice.
Sandra
#11526 - 02/27/08 05:12 PM Re: Interest Charges in Receivables [Re: Sandra]
Hi Sandra,
Perhaps you need to change the interest calculation method in the Company Profile from Overdue Balance to Overdue Invoices?
For example, customer BSC01 in sample data has a balance of 7077.44 and if I change the interest rate to 10%, the interest invoice is 4741.80 based on Overdue Invoices. Based on Overdue Balance, it's only 58.15.
#11527 - 02/27/08 05:22 PM Re: Interest Charges in Receivables [Re: Softrak Support]
Sandra Offline
Loc: Vancouver
Yes, that makes all the difference.
Your help is much appreciated.
Sandra
