#11235 - 02/09/08 11:03 PM Datacare File Integrity Errors
We have recently upgraded from ACCPAC plus and i have scheduled a datacare integrity check each night. Every morning the report says there have been errors in Transaction History or Alternative Price List and each day the number of errors changes, going up or down. At the end of the check it rebuilds and asks to run the check again. This happens each time the check is run. Is this normal? What would cause the data to keep getting these numbers of errors? After it rebuilds wouldn't the errors be fixed? Will it "works it's way out" if i keep running the check and allowing it to rebuild... or will the errors just keep on reiterating themselves?
Thanks!
#11236 - 02/10/08 07:46 AM Re: Datacare File Integrity Errors [Re: ]
Hello kyle775,
It depends on the specific errors that are being reported.
It sounds like you're using DataCare for your overnight checking. One day, run the DIC in Inventory and click the Rebuild button, and keeping doing this until the number of errors stabilizes. Then see what isnecessary to fix the errors that are being reported.
You can cut and paste the error report from the DIC into a post here so we can see the specific errors.
#11238 - 02/10/08 12:08 PM Re: Datacare File Integrity Errors [Re: Retired_Guy]
Thanks for the speedy reply Andrew.
when i run the datacare integrity check overnight all the modules are selected. is there a difference between DataCare and DIC?
I have also noticed that when no one does any work in order entry or retreives anything from OE in sales analysis there doesnt seem to be any errors in Trasionaction history or Alternative price lists.
On monday i will try and run "DIC" in Inventory clicking rebuild.
#11280 - 02/12/08 10:09 AM Re: Datacare File Integrity Errors [Re: ]
i ran the integrity check last night and after having been rebuilt on friday night we see the following
Adagio Inventory: File Integrity
Alternative Price List ... 355 error(s) found .................................. FAILED
Item Alerts ... Checked OK
Bill of Material List Detail ... Checked OK
Bill of Material List Header ... Checked OK
Category ... Checked OK
Smart Finder Control ... Checked OK
Transaction History ... 596452 error(s) found .................................. FAILED
Item Locations ... Checked OK
Item Notes Header ... Checked OK
Item Notes Detail ... Checked OK
Import Export file Details ... Checked OK
Import Export File header ... Checked OK
Import Defaults Field Values ... Checked OK
Items (2) Additional ... Checked OK
Item (3) Extension ... Checked OK
Items (1) ... Checked OK
Price List Codes ... Checked OK
P/O Receipt Detail ... Checked OK
P/O Receipt Header ... Checked OK
Profiles ... Checked OK
Report Set Details ... Checked OK
Report Groups ... Checked OK
Report Header ... Checked OK
Tax File ... Checked OK
Tax Groups ... Checked OK
Units of Measure ... Checked OK
Adagio Inventory: Application Integrity
Skipped due to errors in File Integrity\
near the end of the report it tells me its rebuilt these
Data Repair Phase
Rebuilding Alternative Price List ... Done
Rebuilding Transaction History ... Done
and then it tells me to run the check again..
but this will happen each night no matter how many times it is run it seems.
thanks for any suggestions.
#11345 - 02/15/08 08:15 AM Re: Datacare File Integrity Errors [Re: ]
This is strange, when i run a check from the Inventory Control Module, on a local backup of my data, there are no errors.
#11347 - 02/15/08 09:40 AM Re: Datacare File Integrity Errors [Re: ]
If you are getting integrity errors over the network, but non on a local copy, then your netwok card is failing. Try from another machine to see if it is the workstation or server network card (or it might be a hub or router problem).
#11350 - 02/15/08 10:47 AM Re: Datacare File Integrity Errors [Re: Retired_Guy]
thanks andrew. what a relieving confirmation!
3 registered (AudreyQuick, Howard S.-MMA, Bruce Gardner), 250 Guests and 3 Spiders online.
14589 Topics
February
