Microsoft in all it's wisdom no longer allows you to run CHM help files from the network. A Windows security update prevents this.
Adagio workstation setup copies the CHM help files to the local workstation on the C drive (usually C:\softrak\oewin or C:\softrak\receivables), and puts this path in the Windows registry so that when you attempt to access the help file in Adagio, the program knows where to look for the file.
Something has prevented all of this from happening, perhaps workstation security rights. Certainly you can copy the CHM help files from another location to your local workstation in the desired locations. Eventually you will need to investigate why the workstation setup is not able to correctly copy all the required CHM files or perhaps write to the registry.
