#71434 - 02/18/25 12:40 PM MSVCR110.DLL error
Howard S.-MMA Offline
Maestro
Loc: New York City, NY USA
Hi:
I am trying to do an upgrade at a client. They have 2016-2018 versions but are on support plan.
I started with GridView 93B-20190118 and get this error, then the install stops and exits.
I tried running the installer as Admin but get the same thing.
I ran the GL 93B-20231109 installer and I get the same error. The G/L install finishes but when I try to start Ledger, it wants to do w/s install.
When I do that, I get the MSVCR110.DLL error again, the install finishes but when I try to start Ledger, it wants the w/s install again.
I am logged in as the user who will run Adagio but have full admin rights
Chksys is showing these 2 errors:
========== Checking 32-bit (and higher) System Status ==========
*** Install corruption error, missing: \\oaksrv1\data\Softrak\system\win32\msvcp120.dll
*** Install corruption error, missing: \\oaksrv1\data\Softrak\system\win32\msvcr120.dll
The 2 missing files are NOT in c:\windows\system32
The workstation has Windows 11 Pro, 24H2
Howard Schell
Micro Management Associates
New York, NY USA
bpforum2021@hnyc.us
#71439 - 02/18/25 03:40 PM Re: MSVCR110.DLL error [Re: Howard S.-MMA]
Howard
User does not have enough rights to c:\windows
If I had a dime for every time IT told me that the user has full admin rights only to find out they didn't, I could afford to retire.
#71440 - 02/18/25 05:36 PM Re: MSVCR110.DLL error [Re: Douglas Dickie]
Maestro
I switched to another workstation and was able to install with no problem.
So, yes, probably rights. This workstation was the guy in the company who manages the network.
Yes-A lot of dimes!
Howard Schell
New York, NY USA
bpforum2021@hnyc.us
#71458 - 02/25/25 08:35 AM Re: MSVCR110.DLL error [Re: Howard S.-MMA]
Maestro
OK - So I finally got all their workstations running.
After the problems with the initial install workstation (Windows 11, Version 24H2, Build 26100.3194) noted above, i.e the Adagio Installer error message;
"The file 'c:\windows\system32\MSVCR110.DLL' could not be opened. Please check that your disk is not full and that you have access to the destination directory [OK]"
MSVCR110.DLL did exist in c:\windows]system32.
As noted, we gave up on this workstation and I did the Adagio upgrade from a different Windows 11 workstation with no issues.
I then did the ALLWKST workstation install on 5 other workstations (Windows 10 and Windows 11), also with no issues.
The original workstation that I tried to install from that got the error still displayed the same 'MSVCR110.DLL could not be opened' error when trying to run the ALLWKST workstation install.
I showed the client's outside IT company how to run ALLWKST and let them try to resolve the issue and get Adagio installed successfully on that workstation.
I got it second hand, but they 'updated/copied' MSVCR110.DLL from another Windows 11 workstation.
Then, when they ran ALLWKST again, it gave a similar error message, but this time the error was about a different msvcr/msvcp DLL in c:\windows\system32.
They updated this DLL and ran ALLWKST again, and once again, it complained about another DLL
After about 5 iterations of doing this, the ALLWKST workstation install completed successfully.
I know this is not the best explanation, I have notes scratched everywhere after several days, but I wanted to let tech support and other dealers know of the solution (updating the DLL's in c:\windows\system32) in case they run into this error message.
It seems that perhaps the Adagio install needs to be updated to work with the latest versions of Windows 11-24H2 without getting these errors and having to copy DLL's from other machines.
It did not seem to be a rights issue on the original workstation.
Howard Schell
New York, NY USA
bpforum2021@hnyc.us
0 registered (), 107 Guests and 0 Spiders online.
1865 Members
14418 Topics
February
23 24 25 26 27 28
