Page 2 of 3 < 1 2 3 >
#71604 - 04/08/25 10:29 PM Re: MSVCR110.DLL error [Re: Patricia B.]
To bypass the error, I installed Crystal Reports manually.
#71610 - 04/09/25 11:14 AM Re: MSVCR110.DLL error [Re: Patricia B.]
Hello Rebecca,
It may be “Home Edition” OS. This is from:
Recommended System Requirements for Adagio Accounting
Windows Pro is recommended. No Quality Assurance is performed on Windows Home. Technical Support will not attempt to isolate issues that might surface on Windows Home or networks with Windows Home stations.
Hello Patricia,
I have reminded R&D that your question needs some attention.
#71612 - 04/09/25 02:38 PM Re: MSVCR110.DLL error [Re: Softrak Support]
Rebecca Young Offline
Loc: Toronto, ON
Hi Support,
Per your suggestion, I just upgraded to Windows Pro and it's doing the same thing, so that wasn't the cause.
Please advise on how this can be resolved as this is presumably going to cause problems with all new builds of Windows.
Rebecca
Rebecca Young
J. R. Jacob & Associates Ltd.
rebecca@jrjacob.com
#71613 - 04/10/25 10:20 AM Re: MSVCR110.DLL error [Re: Rebecca Young]
Hello Rebecca,
Thank you for the follow up. R&D is investigating this issue.
#71667 - 04/29/25 12:52 PM Re: MSVCR110.DLL error [Re: Softrak Support]
AudreyQuick Offline
Adagio Ace
Loc: Long Beach, NY
Anything new to report on from R&D. My issue sounds very similar.
Audrey Quick
AGS Enterprises
Bridging the Gap Between Accounting and Computers
www.agsenterprises.com
www.audreyquick.com
https://www.facebook.com/audrey.quick
https://www.linkedin.com/in/audrey-quick/
#71668 - 04/29/25 09:18 PM Re: MSVCR110.DLL error [Re: AudreyQuick]
Loc: Toronto, ON
R&D tried to fix it on my end and couldn't and I was told it's a 'me' problem and they wouldn't help.
I have a standalone desktop, where I have full admin rights and they said I didn't have the right credentials to install (?!). I had no problem installing to a similar computer with a previous build, and had no problems installing other software, it's just Adagio that's causing a problem (all modules give the same problem).
If you figure out how to get around it, please let me know.
Rebecca Young
rebecca@jrjacob.com
#71673 - 04/30/25 08:59 AM Re: MSVCR110.DLL error [Re: Rebecca Young]
Did you try installing Crystal Reports manually? I think the issue is that the Adagio installer is not recognized as a trusted installer.
If you install Crystal and the AdagioV3PDF printer manually, the installer will not need to do that part.
#71674 - 04/30/25 09:23 AM Re: MSVCR110.DLL error [Re: Patricia B.]
AudreyQuick Offline
Adagio Ace
Loc: Long Beach, NY
I had tried installing crystal manually, but I'm also getting a different error related to the SSIBMD32.DLL, not the MSVCR110.DLL. In my case, manual install of crystal did not solve the issue.
https://portal.softrak.com/ubbthreads/ubbthreads.php/topics/71665#Post71665
Audrey Quick
AGS Enterprises
www.audreyquick.com
#71711 - 05/07/25 07:36 AM Re: MSVCR110.DLL error [Re: AudreyQuick]
Loc: Toronto, ON
I tried installing Crystal manually, but still no luck.
Rebecca Young
rebecca@jrjacob.com
#71714 - 05/07/25 02:40 PM Re: MSVCR110.DLL error [Re: Rebecca Young]
Rebecca:
Did you check if the computer is Home edition? It has been reported as a possible issue.
1 registered (1 invisible), 153 Guests and 3 Spiders online.
14589 Topics
February
