#9880 - 09/20/07 12:27 PM Financial Reporter "hide when printed" problem
Ryan Brohman Offline
On smartsheet financial reports, right clicking on column B header and de-selecting the option to "hide when printed" doesn't seem to work, as the column still does not print. It does'nt show in the print preview and it also won't export the column to excel, so printing from there is not an option.
If i delete the A1 cell ".smartsheet" text, then the column displays.
It will also display if i insert a column in front of it - so it seems like it's just column B and only on smartsheets.
I've replicated this with a few different reports on a couple of different datasets.
Ryan Brohman
Kitchener, ON
#9881 - 09/20/07 12:43 PM Re: Financial Reporter "hide when printed" problem [Re: Ryan Brohman]
Michael Mulrooney Offline
On any .SmartSheet statement Columns A and B are automatically hidden when the statement is printed.
This is by design.
#9882 - 09/20/07 12:44 PM Re: Financial Reporter "hide when printed" problem [Re: Ryan Brohman]
Ralph Allan Offline
Ryan,
Softrak Tech Support may correct me on this, but I think that designating the sheet as a SmartSheet requires that it assume control of how columns A and B are used.
If you are trying to display the acct/dept for your detail lines, you could simply choose that as one of the column options when "dragging" into the spreadsheet or use a formula like this:
TRIM(ADGETF("GLDATA.ACCTDEPT",$B8))
(changing the Cell reference, of course).
Ralph Allan
Business Computer Centre
Prince George BC Canada
#9884 - 09/20/07 01:07 PM Re: Financial Reporter "hide when printed" problem [Re: Ralph Allan]
Hi Ryan,
In cell B1, right-click in the cell and choose 'Make .ShowAccounts'. Or simply type .ShowAccounts in cell B1. This allows column B to be unhidden when printing or exporting financial statements with the SmartSheet property.
If you prefer the accounts (and departments if desired) to print with a different format that what is presented in Column B, simply insert a new column C (between Column B and the account description column) and follow Ralph's suggestion above.
Indeed otherwise, columns A and B are always hidden. There are no properties to unhide column A of a SmartSheet, nor would you want to do this.
#9902 - 09/24/07 11:12 AM Re: Financial Reporter "hide when printed" problem [Re: Softrak Support]
Perfect - thanks guys! .ShowAccounts did the trick.
Ryan Brohman
Kitchener, ON
14576 Topics
