#9633 - 08/10/07 11:01 AM ledger finanancial reporter locking out users?
David Dearin Offline
Loc: Heffley Creek, BC
System has all supplied updates applied. Lanpak/5, ledger, ap, ar and invoices.
Yesterday when one user was in the ledger financial reporter any other users could not access adagio at all. The error message did not indicate record locking, but rather something about incorrect procedure. Unfortunately I was not onsite and did not see the actual message, but handled the issue over the phone. We eventually figured out someone had the financial open and once they closed them the users again had access.
Is this something to do with the new lanpak?
David Dearin
#9635 - 08/10/07 11:05 AM Re: ledger finanancial reporter locking out users? [Re: David Dearin]
Sorry double post.
Too quick on the mouse.
David Dearin
#9636 - 08/13/07 07:35 AM Re: ledger finanancial reporter locking out users? [Re: David Dearin]
Ryan Brohman Offline
Hi David,
I tried this out in our office. Opened up financial reporter from within the ledger, loaded a balance sheet spec, and tried signing in to the same data set from a different computer and using a different user name. I was able to login without a problem to AP, AR and GL.
Was this a "one off" situation for your client, or has it happened again?
I might suggest cutting out the ezsemtab.xxx file from their data if it happens again - it could have become corrupted. The file will be recreated as soon as someone logs back into Adagio and this will reset all the program locks.
Ryan Brohman
Kitchener, ON
#9655 - 08/14/07 10:22 AM Re: ledger finanancial reporter locking out users? [Re: Ryan Brohman]
Yes it was a "one of a kind"
Have not heard any porblems lately but now I think they are gun shy about the financials.
I will do some more testing.
Thanks for the ezsemtab tip/
David Dearin
#9749 - 08/28/07 02:51 PM Re: ledger finanancial reporter locking out users? [Re: David Dearin]
I just experienced the same problem as David. I am in financial reporter and tried to open the payables module and got the following error:
Version Compatability: Your current version of Adagio Payables is not compatible with the version of Adagio Ledger database you are currently using. Complete compatibility information can be found at http://www.softrak.com/appcomp.php
So then I asked my coworker to attempt to sign in and she got the same error.
This is not a "one-off" error. We have replicated this error several times over the morning.
Is there a "fix" that Adagio can provide? It is not feasible to have other users locked out of the program while one person is printing or programming a financial statement.
#9750 - 08/28/07 03:05 PM Re: ledger finanancial reporter locking out users? [Re: ]
Hi Sonia,
What version of Adagio Payables are you using? Presumably 8.1A, but what is the release date? There are hot fixes available that have fixed some issues where 'incompatible program' errors were erroneously appearing.
Business partners can download these hot fixes from the Softrak website in the partner area. These have not yet been released as Service Packs.
#9751 - 08/28/07 04:22 PM Re: ledger finanancial reporter locking out users? [Re: Softrak Support]
All the Adagio modules we have installed are 8.1A.
This not only happened with Payables, but also with Invoices, Job Cost and Receivables.
Is there an ETA on the Service Packs?
#9754 - 08/29/07 09:59 AM Re: ledger finanancial reporter locking out users? [Re: ]
Hi, Sonia,
We don't have an exact date on the release of a Service Pack yet. The hotfixes which address the compatibility messages are available in the partner/dealer area of our website though.
#9759 - 08/29/07 01:21 PM Re: ledger finanancial reporter locking out users? [Re: Softrak Support]
That's very unfortunate for me, but not for you, I guess!
We have enough technically savvy personnel in this office that we can download and install our own Service Packs, yet instead you are telling me that I have to contact AND PAY our partner/dealer to install this for me.
I'm disappointed with this, and I feel this practice is unfair to the end user.
We already pay annual update fees to ensure that we have the latest and greatest versions of the software, but once again we have to open our chequebooks in order to eliminate a "bug" that you've already discovered but are refusing to release without further compensation, and have given me no indication as to when it will be released as a service pack, if ever.
This ?fix? should be offered to the end-user as soon as possible. We are already out-of-pocket due to this error by having staff get locked out and disrupting their work. We shouldn?t also be penalized monetarily to repair your error. On top of that, we will also have to wait for the partner/dealer to have time in their schedule to install the fix, so once again, we are losing money. It is understandable that all software packages and upgrades will have issues, but it is incomprehensible that you are instructing me to pay to have the bugs worked out of your program. We have paid for the program, we pay annually for updates, how much more do we have pay to use your program without it costing us time and money every time we login?
#9760 - 08/29/07 02:38 PM Re: ledger finanancial reporter locking out users? [Re: ]
Hi Sonia,
I have sent you a link by email for the Adagio Payables 8.1A hot fix. Install this and give it a try to see if this helps with your situation. We will send the others if it does help.
It may be that the problem you are experiencing is not caused by the scenario the hot fix addresses, but something else entirely - such as the situation Ryan posted further up this thread. Should the problem at your company not be solved by installing the hot fix, then please indicate what versions and release dates of Adagio Ledger and Adagio Payables are currently installed. Also, can the same error message be replicated by opening the Adagio Payables sample data in the \softrak\apwin\samdata directory - in case the situation is localized to your live data.
We want dealers to be involved where Hot Fixes are concerned. Hot Fixes generally have not had as much testing as a Service Pack and do not include an updated Readme or Release Notes. A dealer who is familiar with your site can ensure there will not be any compatibility or other install issues. The dealer may want to charge for their time and expertise, or they may simply forward the Hot Fix for you to install yourself.
1 registered (Tanya_Belanger), 94 Guests and 1 Spider online.
14624 Topics
