#967 - 03/13/01 08:09 PM QRW 6.2a
I have a client with QRW 6.2a and we have run into problems with it.
AR/OE 6.1b
A report modeled after OE 6.1b invoices and credit notes has these following problems.
1. Attempts to create record filters do not seem to work if you have more than two selection criteria. Provides 2 and generates the report.
2. Attempts to export to excel 5 crash with a message "Report has more than 16350 records"
What is the problem here? Bugs in QR 6.2a? What can we do short of scrapping QR for win?
#968 - 03/14/01 12:42 PM Re: QRW 6.2a
Dear vla,
QRW6.2A should have no problem with reports created with AR and OE 6.1.
1. The syntax of your selection formula could be responsible for limiting the data you are getting. The formula itself is likely ok, but the way you have it constructed has everything to do with what data is pulled. Please provide more information on what fields you have on your report, and what the Selection Formula is (type it in here exactly as it appears in QRW).
2. Older versions of Excel will not handle more than 16350 records. QRW does not have this limit.
Even though you are using an older version of QRWIN now (current release is 6.2B 010128), this should not be the problem.
Will be awaiting more detailed information on item #1 to assist you further.
0 registered (), 267 Guests and 3 Spiders online.
14653 Topics
