#9668 - 08/14/07 03:42 PM Costing Screen and Item Vauation Report
(162.83.106.158)
1. What makes up the most recent cost?
2. The fields date of change on the costing screen - where
does this information come from?
3. From the item valuation report what makes up the actual cost?
#9671 - 08/14/07 04:22 PM Re: Costing Screen and Item Vauation Report [Re: ]
Hi orlanda,
1) If you receive an item, either from a Receipt (either in Adagio Inventory or a 3rd party Purchase Orders program), the cost from the receipt gets copied to the Most Recent Cost field. This field can also be edited manually.
2) If the Most Recent Cost amount changes for any reason, the date that the change was made is recorded. This way you know the last time the cost was changed.
3) The Total actual cost can be found on the Item Inquiry with Sales and Costs, on the Cost screen. This total will equal the sum of the costing lots after all Day End Processing procedures are run. The Unit actual cost is a simple calculation of the Total actual cost divided by the qty on hand (also found on the same Costing screen mentioned above).
#9672 - 08/14/07 04:29 PM Re: Costing Screen and Item Vauation Report [Re: ]
Ralph Allan Offline
(70.77.34.36)
1. Most recent cost is updated each time you purchase the item.
2. Date shows the date of the last time the Most recent Cost changed.
3. The calculation for average cost depends on the costing method. Moving average is obvious, the FIFO and LIFO are not.
Say you buy 10 items at $1.00 each. The first costing bucket shows $10 and 10 Items.
Then you buy 5 more at $1.10 each. The second conwsting bucket shows $5.50 and 5 items,
Overall you would have 15 items at a total cost of $155 or $1.03 each.
Now if you sell 12, the first 10 cost $10 total and the next two cost $2.20 total for a cost of $12.20 or about 1.02 each. Left in stock are 3 items at a total cost of $3.30 or $1.10 each.
There are 5 buckets, tracked separately.
If you drive your quantity on hand below zero, you will -- in every inventory system I have seen -- totally mess up the cost calculations.
Ralph Allan
Business Computer Centre
Prince George BC Canada
1 registered (1 invisible), 120 Guests and 8 Spiders online.
14567 Topics
