#9472 - 07/19/07 03:03 PM
Invoices & Receivables 8.1A
The new versions are requiring me to enter a salesperson for every customer account. Is there any way to turn this "mandatory" function off?
When it gives me the warning to "enter a valid salesperson", I click OK to acknowledge the warning, and then it automatically enters the last salesperson code that I had used. This could cause us some trouble.
How do I fix this?
#9475 - 07/19/07 04:44 PM
Re: Invoices & Receivables 8.1A
[Re: Softrak Support]
I'm curious as to why the salesperson code is now mandatory. The old versions did not require this. Is there a "quick" way to update this field, as now I have to go through all my customers, inconveniently, and update the salesperson so that someone does not accidentally accept the 'last saved code'.
#9477 - 07/19/07 05:02 PM
[Re: ]
Hello Sonia,
The quickest way is to create a SmartFinder (F6) query containing the information you need to assign a salesperson code (perhaps customer number, name, territory - or phone, and salesperson). Select all your customers using the filter "Cust # not equal blank" and send the result to Excel. Use Excel to fill in the appropriate salesperson code. Then create an import template (File | Import | Customers) naming the columns in order and specifying not to add any records and import your spreadsheet. Make a backup before doing the import.
Alternatively, you can just export the customer numbers and names where the salesperson is blank and save the Excel list. Then import the list, setting the salesperson to one you've added (perhaps "HOUSE") using the field default in the import template.
BTW - you're right that this edit has been added in V8.1 - our documentation has always said that this field was required when running OrderEntry or Invoices. After a review of all the possible scenarios, we'll probably relax this requirement in Receivables when we release OrderEntry V8.1 (in a couple of weeks) since it has tighter editing on creation of an invoice.
Sorry for the inconvenience.
#9479 - 07/19/07 05:25 PM
[Re: Retired_Guy]
I just printed a Smart query out of Adagio Invoices, as I wanted to see what it looked like.
The report printed with the wrong company name on the top! We operate 2 companies using Adagio, and it printed the name of the company that the program is registered to. I have checked the profiles on all the modules and they are correct.
How do I change this? For obvious reasons we cannot have any reports printing with the wrong company name on the top!
#9488 - 07/20/07 05:26 PM
[Re: ]
Sonia,
If some of your customers are not associated with a particular salesperson, one common idea is to create a Saleperson called "House Sales" and assign that one.
#9489 - 07/20/07 05:30 PM
[Re: Ralph Allan]
Thank you, Ralph, that is exactly what I have done.
#9554 - 07/28/07 01:52 AM
[Re: Douglas Dickie]
Hi Doug,
The hot fix is available now to any who need it. They just need to contact their Adagio Partner.
0 registered (),
43
Guests and
2
Spiders online. |
