#9409 - 07/09/07 11:37 PM Printing Shipping Labels in Order Entry
Taylor Offline
Loc: Alberta Canada
Is it possible to print shipping labels for invoices done in Order Entry? Does anyone have any hints at how to get them to print so there is more than one on a page?. Can a dot matrix printer be used? Any help would be appreciated. Thanks.
#9410 - 07/10/07 12:11 PM Re: Printing Shipping Labels in Order Entry [Re: Taylor]
Yes, there's more than one way of printing labels:
(1) you can highlight the invoice and either click on the Print Labels button or right click and select print labels, but this will only print for the one invoice; or
(2) you can access the OrderEntry menu and select Print Shipping Labels. Here, you can select invoices from the dropdown then enter a starting and ending range of document numbers to print the labels for.
There are also a few different sample label specifications provided with Adagio OrderEntry and, yes, you can print more than one label per page.
If you want to modify any of the sample label specifications, access the Maintenance menu and select Maintain Specifications. From here select File and Open Template. You can then modify the selected specification as you want to.
When you save the specification, give it a name beginning with OE$ and it will be saved into your data directory with the 3 character extension of the dataset you have open.
0 registered (), 285 Guests and 2 Spiders online.
14666 Topics
