#9302 - 06/26/07 11:23 AM IC Integrity
Fong Offline
Adagio Ace
Item count is 395, but should be 393? I don't understand. Where're the extra pieces came from? Please comment. Thanks.
Loading Tax Groups ... OK
Company Profile ... Checked OK
Orphan Item S28873 secondary record will be deleted.
Items ... 1 error(s) found
Alternative Price List ... Checked OK
Category BLB item count is 395, but should be 393
Category STL item count is 537, but should be 530
Category ZZZ item count is 4566, but should be 4565
Categories ... 3 error(s) found
#9305 - 06/26/07 12:05 PM Re: IC Integrity [Re: Fong]
Hello Fong,
Somehow the count of the number of items assigned to a particular category in Inventory became incorrect. If you press the Rebuild button, the count will be adjusted to reflect the actual number of items assigned to that category.
Without knowing exactly what you have done between the last integrity check that did not have these errors, and the current integrity check, it is impossible to know what might have caused these errors.
This count is only used to make sure you don't delete a category being used by an item. There's no other risk associated with correcting the count.
2 registered (Douglas Dickie, 1 invisible), 233 Guests and 2 Spiders online.
14672 Topics
