#9259 - 06/20/07 06:06 PM GL Financial Reporter - Line Suppress
Kay Offline
Loc: Fowler, CA, USA
In Accpac there was a ".Z {R}" command "The Suppress Zero Lines specification prevents lines containing zero figures (except totals) from being printed".
Q: Is there an equivalent command in the Adagio Reporter and NO, I don't want to use Smartsheets.
There is very useful for management reports that have different active/used accounts across various departments and still be able to use the same report both separate and consolidated.
Kay N. Paboojian, Jr.
#9261 - 06/20/07 06:33 PM Re: GL Financial Reporter - Line Suppress [Re: Kay]
Michael Mulrooney Offline
Click on the red octagon with the line through to suppress zeroes in any financial statement. You will need to use "Print Preview" to see the lines being suppressed; they will continue to appear on the screen.
#9262 - 06/20/07 07:17 PM Re: GL Financial Reporter - Line Suppress [Re: Michael Mulrooney]
You can also specify particular rows to not be suppressed when all numeric amounts are zero. Just highlight a row and right-click. The pop-up menu will allow you to uncheck the zero-suppress setting.
#9299 - 06/25/07 10:59 PM Re: GL Financial Reporter - Line Suppress [Re: Softrak Support]
Kay Offline
Thanks to both of you. I thought I had tried this/both but I misinterpreted the results in the print preview. I have verified both work and will work toward a consistent implementation.
Sorry for the late acknowledgement, but I was unavailable to check the website recently.
2 registered (Douglas Dickie, 1 invisible), 233 Guests and 2 Spiders online.
14672 Topics
