#908 - 01/29/01 01:01 PM Re: Data Care 6.5A (991020)
Dear Dayle
I have never heard of a mouse/mouse driver causing problems. Have you tried starting DC from another workstation - to eliminate this one being a problem?
The other thing you can check is that the user of this PC did not start running a Screen Saver, as there is a known problem with screen savers producing the same symptoms as you are describing - where DC has seemingly stopped in the middle of a check, or in your case, has not started yet and when the machine is accessed the next morning - that is what the User sees.
Hope this helps.
#910 - 01/29/01 05:58 PM Re: Data Care 6.5A (991020)
Sounds good, Dayle. Hope that resolves it.
Take care
#912 - 01/30/01 12:49 PM Re: Data Care 6.5A (991020)
Hey - that's GREAT news!
We don't know why using a screensaver distorts the way DataCare interprets the time or otherwise interferes with the check, however, this is the only work around that we have found.
Take care!
14630 Topics
