#8984 - 05/09/07 11:31 AM Export from TB/Import to ledger
bal Offline
Adagio Ace
Loc: Ottawa
Is there an easy way to export monthly disbusements on certain projects to a file that I can import to the GL?
We have internal corporate projects that we track using TB. Since the expenses will never be recovered, at the end of each month, I am billing them out for $0, then manually distributing them to the appropriate expense accounts.
I am thinking that there has to be a better way.
If I export the disbursements from Gridview into an Excel spreadsheet amd make the adjustments, is there a way to import them into the ledger as a batch that I can post?
Thanks.
#8989 - 05/09/07 04:09 PM Re: Export from TB/Import to ledger [Re: bal]
Hi bal
If you can export something to Excel, then, by definition, you can import it to Ledger as a batch. You may have to massage the Excel file a bit.
Look at the sample Excel import templates in the sample Ledger data (\SOFTRAK\ALWIN\SAMDATA)
