#8690 - 03/20/07 10:53 AM Data Integrity Error in IC
Fong Offline
Adagio Ace
Please tell me what this message means:
Items (2) Additional ... 4 error(s) found ...................................... FAILED
Adagio Inventory: File Integrity
Alternative Price List ... Checked OK
Item Alerts ... Checked OK
Bill of Material List Detail ... Checked OK
Bill of Material List Header ... Checked OK
Category ... Checked OK
Smart Finder Control ... Checked OK
Transaction History ... Checked OK
Item Locations ... Checked OK
Item Notes Header ... Checked OK
Item Notes Detail ... Checked OK
Import Export file Details ... Checked OK
Import Export File header ... Checked OK
Import Defaults Field Values ... Checked OK
Item (3) Extension ... Checked OK
Items (1) ... Checked OK
Price List Codes ... Checked OK
P/O Receipt Detail ... Checked OK
P/O Receipt Header ... Checked OK
Profiles ... Checked OK
Report Set Details ... Checked OK
Report Groups ... Checked OK
Report Header ... Checked OK
Tax File ... Checked OK
Tax Groups ... Checked OK
Units of Measure ... Checked OK
Adagio Inventory: Application Integrity
Skipped due to errors in File Integrity
#8692 - 03/20/07 12:00 PM Re: Data Integrity Error in IC [Re: Fong]
Hello Fong,
It means that the index into the secondary file containing item information (extended description, vendor part number, etc.) does not match the item number stored in the file. Usually a "Rebuild" will fix this problem, but you should then run the data integrity check again to make sure that the data itself is clean. A damaged index prevents the second phase of the integrity check from running.
#8697 - 03/20/07 04:17 PM Re: Data Integrity Error in IC [Re: Retired_Guy]
Fong Offline
Adagio Ace
Funny our DIC's Rebuild function only works from time to time.
#8700 - 03/20/07 04:43 PM Re: Data Integrity Error in IC [Re: Fong]
Hi, Fong,
Rebuild only becomes active when the program finds errors it can possibly rebuild. Sometimes, errors cannot be rebuilt by the program. Sometimes, it might be a case of requiring a data repair.
0 registered (), 287 Guests and 5 Spiders online.
14584 Topics
February
