#8636 - 03/13/07 11:42 AM Data Integrity Errors
Fong Offline
Adagio Ace
Re: Adagio Inventory: file Integrity
Hi, can you tell me what causes Transaction History file error?
I have 427,171 errors found last night. Data Repair has fixed the errors.
#8637 - 03/13/07 11:55 AM Re: Data Integrity Errors [Re: Fong]
Ralph Allan Offline
The most common source of such a large number of errors is deleting items for which history records exist.
Ralph Allan
Business Computer Centre
Prince George BC Canada
#8638 - 03/13/07 12:53 PM Re: Data Integrity Errors [Re: Ralph Allan]
Hello Fong,
A damaged index will also cause a large number of errors. The rebuild function fixes the problem. You should run the integrity check again to make sure that the dataset is "clean" before working with it again.
Having a problem like this may occur due to bad power, operator error, a bad network card or network router. A single occurrance can be written off to "act of Windows". Multiple frequent occurrances point to a hardware problem.
#8641 - 03/14/07 01:25 PM Re: Data Integrity Errors [Re: Retired_Guy]
Fong Offline
Adagio Ace
Thank you all for your help.
I have run another integrity check last night. Same file error happen again. No, we didn't delete any inventory item lately.
Now is it ok to continue daily data processing until the problem is identified? Would you suggest something we should do in the meantime? Our Adagio consultant is too busy for us lately. Thanks.
#8642 - 03/14/07 02:12 PM Re: Data Integrity Errors [Re: Fong]
Hello Fong
Is it one file or a set of files that have the problem?
After you rebuild the indexes, does the integrity check pass clean?
#8643 - 03/14/07 02:55 PM Re: Data Integrity Errors [Re: Retired_Guy]
Fong Offline
Adagio Ace
Hi Andrew.
I didn?t run integrity check again right away after the first run. It?s impossible to run integrity check in the working hours for so many users accessing Plus or Adagio.
Run #71
Adagio Inventory: File Integrity
Transaction History ... 427171 error(s) found .................................. FAILED
Summary
File Integrity ... 427171 error(s) found ....................................... FAILED
Finshed at: 2007.03.13 04:37
Data Repair Phase
Rebuilding Transaction History ... Done
Finished rebuilding integrity errors.
Please repeat Data Integrity Check.
Run #72
Transaction History ... 240736 error(s) found .................................. FAILED
File Integrity ... 240736 error(s) found ....................................... FAILED
Summary
Finshed at: 2007.03.14 04:36
Don?t know why but this time no data repair was attempted.
1 registered (1 invisible), 182 Guests and 2 Spiders online.
14667 Topics
