#8372 - 02/08/07 08:43 AM Unable to process dayend
Salesperson" not found on invoice Unable to process dayend. Deleted order and credited invoice and still cannot dayend.
#8376 - 02/08/07 02:28 PM Re: Unable to process dayend [Re: ]
1. Run Data Integrity Check and do what it says.
2. Why didn't you just add the salesperson code?
#8378 - 02/08/07 02:31 PM Re: Unable to process dayend [Re: Steve Schwartz]
Already ran the integrity check nothing happened.
Tried to add the salesperson code after the fact but cannot make any changes to the invoice.
#8380 - 02/08/07 03:31 PM Re: Unable to process dayend [Re: ]
We will contact M&G right away.
There is a workaround. Basically in an OE template (Maintenance | Define OE Entry Template) and within Group Security (File | Group Setup), make sure that on the Customer tab if you have Salesperson, Enter on New, you have also clicked on the Finder field and specified a particular salesperson. This will prevent a Salesperson field from being left 'blank' as it is a required field in OE.
