#7798 - 10/26/06 10:53 AM GridView Help!
I started using GridView for the first time after watching the last Webinar on Tuesday and I was able to create my first workspace. I saved this workspace into a View Folder under \softrack network folder...\DATA\CompanyName.
I can go into AR and Lunch this Workspace from the INQUIRIES--> VIEWS menu. This starts gridview and opens the workspace. Unfortunately when Gridview gets started this way on my computer, I'm not able to make any changes to the WORKSPACE.
I think adagio GridView was not install properly on my computer... I can edit the workspace when I do the same thing from someone else's computer or if I lunch it from a shortcut in a shared folder on our server.
Can you help?
Yann
#7799 - 10/26/06 11:26 AM Re: GridView Help! [Re: ]
Ralph Allan Offline
Dawn,
When you launch GridView from the Inquiries menu in an Adagio Application, it opens in "read only" mode. This allows users to view the reports (and print and export them to Excel if allowed in the setup) but not change them.
To make changes, launch GridView from the menus or desktop. The icon or menu item must have /c after the program name to allow creation/changes/editing.
Ralph Allan
Business Computer Centre
Prince George BC Canada
#7800 - 10/26/06 11:31 AM Re: GridView Help! [Re: Ralph Allan]
Hi Yann,
Actually, the situation is that the user record does not have 'Edit Gridview' enabled. To make sure this is set, go into an Adagio program where you load the inquiry, and from the File menu, pick Users (if you have access). Edit the particular user record and make sure the 'Edit Gridview' selection is appropriately determined.
Workspaces can be editable with the setup above.
#7801 - 10/26/06 02:09 PM Re: GridView Help! [Re: Softrak Support]
Thank you.
Problem solved.
14617 Topics
