#70248 - 10/05/23 10:39 AM =ACCOUNTGROUP and Dept List problem
Wendell Friesen Offline
Loc: Grande Prairie, Alberta
When I use the =ACCOUNTGROUP formula in Column B I get incorrect results if I use anything but consolidated departments. This is my formula:
=-ADGET("GLDATA.Y",$B7) and in cell B7 I have:
=ACCOUNTGROUP("FS","SOps","Rev","ISC")
I have set up department lists and want to get reporting on these lists using the Accountgroup formula. Is this possible?
I also noticed that the displayed amount when I use a department list is different that than the amount I get if i drill down on the value.
I am obviously using the wrong formula. Can anyone point me in the right direction?
#70250 - 10/05/23 11:16 AM Re: =ACCOUNTGROUP and Dept List problem [Re: Wendell Friesen]
Hello Wendell,
Have you looked at the Help in Financial Reporter? Based on your description, you may need to use:
=ACCOUNTGROUPDEPT(string1[,string2[,...string]])
Instead of:
=ACCOUNTGROUP(string1[,string2[,...string]])
#70251 - 10/05/23 11:24 AM Re: =ACCOUNTGROUP and Dept List problem [Re: Softrak Support]
I did try that but to no avail.
#70252 - 10/05/23 11:28 AM Re: =ACCOUNTGROUP and Dept List problem [Re: Softrak Support]
It seems to be that the missing "-`" from each account or range in the account group is where the issue is. Is there a way to overcome this?
#70253 - 10/05/23 11:35 AM Re: =ACCOUNTGROUP and Dept List problem [Re: Wendell Friesen]
Hello Wendell,
Including a place holder is the purpose of the formula.
From the Help file:
ACCOUNTGROUPDEPT() returns the range of accounts with the departmental place holder (`).
#70255 - 10/05/23 12:02 PM Re: =ACCOUNTGROUP and Dept List problem [Re: Softrak Support]
That doesn't work. My ACCOUNTGROUP statement references the name of the the group and I have accounts dragged in to that group. Adadio comes up with a list separated by commas.
My work around is to copy the range from the properties of the ACCOUNTGROUP and add -` to every account or range. Very tedious and will need to be maintained if I add any more accounts to the group. There must be a better way.
