#677 - 09/22/00 09:59 AM Quik reports 6.1A running slow
what can I do to fix this?
Just a few weeks ago Quik reports was running very quickly about 20 secs to put up a report. Now it takes about 15 min for a report to come up.
What can I do to fix this??
thanks
#678 - 09/22/00 12:40 PM Re: Quik reports 6.1A running slow
Hi Cman,
If you are running Quik Reports 6.1A, you may want to consider upgrading, as this version is about 10 years old or more. There have been many modifications, including using some extended memory to run reports in addition to conventional memory.
Please note that this version of Quik Reports is not Y2K compliant.
In the meantime, you should check the workstation and try to free as much conventional memory as possible. A minimum is 530K for simple reports, and up to 580K for more complicated reports. If you have installed anything new onto your computer, that could have removed some of the memory from your machine. Also, if you have installed any network service packs, this could also influence performance.
I assume that you haven't modified your report at all, including adding new fields or editing the links. These things can affect the speed of the report.
#679 - 09/22/00 01:23 PM Re: Quik reports 6.1A running slow
the version is actually 6.1F which is still probable not Y2K complient
it just seems strange that up until about 2 to 4 weeks ago it was working fine and now it is slowing down??
the network is fine and the workstations have enough memory to run
is there anything else that I could look at??
1 registered (Bruce Gardner), 436 Guests and 2 Spiders online.
14643 Topics
