#61249 - 06/21/19 11:10 AM PurchaseOrders 9.3A - Importing PO's
When importing a PO from a CSV file, there is no way to import the unit of measure for a detail line (like there is in OrderEntry, for example). The imported detail line defaults to the Cost Unit of Measure as defined in the item master.
Is there a way around this? A client needs to default the Cost Unit of Measure to 1000s (because the unit cost is so small) but they purchase by EACH.
PS - if we could cost out to 4 decimals in Inventory instead of 2, this would alleviate the problem.
#61332 - 07/02/19 09:30 AM Re: PurchaseOrders 9.3A - Importing PO's [Re: Steve Schwartz]
Brian Stief Offline
Waterloo Guy
Hi Steve,
We have requested the same issue resolution previously, so hopefully your request gets added to ours.
If you can resolve with 4 decimals in IC, you can use alternate pricelists (IC) enabled in Purchase Orders, with the unit price set to 4 decimals.
The Markup cost on the Alternate Price List is the the purchase unit price, and you set the 4 decimals on the second screen. To use, you can set the Price List on the Vendor Record.
For actual 4 digit inquiries of item costs, we use Gridview,
We'll use this configuration for many sites needing 4 decimals for the unit price.
Best,
Brian
Brian Stief,CPA,CA
800.540.3164
#61337 - 07/02/19 11:03 AM Re: PurchaseOrders 9.3A - Importing PO's [Re: Brian Stief]
Thanks Brian
That's a beautiful workaround and I will bounce it off of my client.
#67602 - 01/18/22 03:15 PM Re: PurchaseOrders 9.3A - Importing PO's [Re: Steve Schwartz]
Hello Steve & Brian,
The PurchaseOrders 9.3B (2022.01.13) Upgrade does include the unit of measure in Importing Transactions for IC Item details.
0 registered (), 74 Guests and 1 Spider online.
1869 Members
14602 Topics
