#67551 - 01/12/22 11:58 AM Fncl Reporter, hard page break settings to print
Holiday Offline
Wondering how to set a hard page break in Financial Reporter.
I have searched the help, but can seem to find this option.
Thanks, Sue
#67555 - 01/12/22 12:35 PM Re: Fncl Reporter, hard page break settings to print [Re: Holiday]
Hi Sue,
With the Financial Reporter and the desired statement open, highlight the row where you want to insert a page break. Then from the Edit menu, select Insert Row Page Break. Or you can use the Control-B keyboard shortcut. When inserted, you will see a red line above the row number to visually indicate where the page break is.
There is also a setting to add a Column Page Break, if your statement has enough columns that would force it to print on more than one page wide. Though typically you would want the entire statement to print on a single page wide. Just pointing out the additional setting.
0 registered (), 210 Guests and 3 Spiders online.
14631 Topics
