#67438 - 12/17/21 01:19 PM PO 9.3A Receipt Status
Is there a field I can add to the Receipts grid that displays whether the the receipt was posted as a delivery note or as an invoice?
I know there is a report called the Outstanding Receipt Invoice List that only shows receipts that have been posted as a delivery note, so I have a feeling the answer is yes.
#67456 - 12/17/21 02:59 PM Re: PO 9.3A Receipt Status [Re: Steve Schwartz]
(207.194.135.206)
Hi Steve,
Yes, the 'totDoc Type' field displays the Document Type of Delivery Note or Invoice on the Rcpts-All Vendors tab.
This information is stored in the Totals data file - since you could have a receipt with two vendors, one of which gets a Delivery note and the other gets an Invoice. This means that the Rcpts-Primary Vendor tab will not be able to display this column information. Only the All Vendors tab.
#67483 - 12/28/21 08:19 AM Re: PO 9.3A Receipt Status [Re: Softrak Support]
Samuel Kopstick Offline
(76.71.30.54)
As well, is there a way to add the PO document # to the Rcpts-All Vendors" grid?
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#67484 - 12/28/21 08:54 AM Re: PO 9.3A Receipt Status [Re: Samuel Kopstick]
Hi Samuel
That would be tough because there isn't a one-to-one relationship between a Receipt and PO. Specifically, you can combine multiple POs on one Receipt.
#67485 - 12/28/21 12:17 PM Re: PO 9.3A Receipt Status [Re: Steve Schwartz]
At the detail level, Softrak should add a field for the original PO #
#67486 - 12/28/21 12:38 PM Re: PO 9.3A Receipt Status [Re: Douglas Dickie]
Hi Doug,
That is already possible.
#67493 - 12/29/21 09:54 AM Re: PO 9.3A Receipt Status [Re: Softrak Support]
Support:
Thanks for confirming. I didn't doubt Steve so I didn't verify - even though I thought the field already existed.
#67494 - 12/29/21 11:11 AM Re: PO 9.3A Receipt Status [Re: Douglas Dickie]
Tech support's answer doesn't change my reply.
It would be tough to get the PO number on the "Rcpts-All Vendors" grid because there isn't a one-to-one relationship between a Receipt and PO.
#67499 - 12/29/21 03:08 PM Re: PO 9.3A Receipt Status [Re: Steve Schwartz]
Steve:
This is a good example of where GV shines.
1 registered (1 invisible), 120 Guests and 8 Spiders online.
14567 Topics
