#66245 - 06/03/21 07:31 AM GV - Lookup data question
Samuel Kopstick Offline
I need to lookup & display records that have text anywhere in the Description field from PO details.
I am using a formula: FINDANY({detDescription} ,"steel", "iron", ”brass” ) = 1
Everything is working nicely. But now I have two questions:
1. The text I look for can be anywhere in the Description field.
How can I display in a separate column the text of the look-up word that we are searching for? (e.g. Display the text: “Steel”, “Iron”, “Brass” in a separate GV column)
2. I may need to lookup about 10-20 items.
Is there a more appropriate method to lookup this data?
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#66246 - 06/03/21 08:23 AM Re: GV - Lookup data question [Re: Samuel Kopstick]
Hi Samuel,
This is a perfect use-case for TABLEFIND(). Take a look at the Help text for the function and there should be an example workspace TABLEFIND.GVS in \Softrak\gvwin\Views,
Ask more questions if this isn't enough explanation.
#66249 - 06/03/21 09:10 AM Re: GV - Lookup data question [Re: Retired_Guy]
Thank you, Andrew. I will check it out and let you how this works out.
Samuel Kopstick
Toronto, ON
#66257 - 06/07/21 07:20 AM Re: GV - Lookup data question [Re: Samuel Kopstick]
Andrew: What am I missing?
I am looking at the GV Workspace "Tablefind.gvs". It opens two views.
Nowhere (at least what I see) is there a column/field/formula that is using TABLEFIND().
Samuel Kopstick
Toronto, ON
#66259 - 06/07/21 09:05 AM Re: GV - Lookup data question [Re: Samuel Kopstick]
Hi Samuel,
The TABLEFIND() function is used in the Filter of the TABLEFIND View.
0 registered (), 102 Guests and 2 Spiders online.
1869 Members
14602 Topics
